///BHRpowered Posted June 16, 2008 Report Share Posted June 16, 2008 So now I have my first actual problem with a millenia, not so much a problem as it drives me crazy. Drivers side window goes just a bit slower then passenger side, annoying but ok My problem is that when going down it sounds like muffled nails on a chalk board, when the window is going up its still a bit slow but doesn't make the noise, its really starting to get to me since I always drive with the windows down. I tried some WD-40 in the side track which helped ALITTLE but only last a few days. Any ideas of where else to lube and or fixes? Link to comment Share on other sites More sharing options...
latinopikachu Posted June 16, 2008 Report Share Posted June 16, 2008 the G'old Beast used to do that. It is probably a slightly dry bearing in the regulator. Link to comment Share on other sites More sharing options...
Frankzao Posted June 16, 2008 Report Share Posted June 16, 2008 does this mean he drives it every day? Link to comment Share on other sites More sharing options...
latinopikachu Posted June 16, 2008 Report Share Posted June 16, 2008 no it means his window is worn out because he never ever EVER uses the AC as he has told us, letting dirt and dust infiltrate his interior Link to comment Share on other sites More sharing options...
Frankzao Posted June 16, 2008 Report Share Posted June 16, 2008 everyday.... Link to comment Share on other sites More sharing options...
///BHRpowered Posted June 16, 2008 Author Report Share Posted June 16, 2008 there is no dirt or dust, actually its done it for a few years, I think I just noticed it more rolling the window down while inside the carcapsule Any idea WHICH bearing or procedure for greasing? Link to comment Share on other sites More sharing options...
mts Posted June 16, 2008 Report Share Posted June 16, 2008 Take the door apart and have an adventure. It is probably more likely the window guide rails that are dry and squealing. Link to comment Share on other sites More sharing options...
///BHRpowered Posted June 16, 2008 Author Report Share Posted June 16, 2008 I had the door panel off and everything recently for a speaker, couldn't see any decent way to access them Link to comment Share on other sites More sharing options...
mts Posted June 16, 2008 Report Share Posted June 16, 2008 Pull the plastic sheet, and reach in... Link to comment Share on other sites More sharing options...
///BHRpowered Posted June 16, 2008 Author Report Share Posted June 16, 2008 still have to see Link to comment Share on other sites More sharing options...
latinopikachu Posted June 17, 2008 Report Share Posted June 17, 2008 be very very careful because that fucking black stuff DOES NOT COME OFF. Link to comment Share on other sites More sharing options...
///BHRpowered Posted June 17, 2008 Author Report Share Posted June 17, 2008 umm, yes it does, its annoying, but it comes off, of you could be smart and just peel it away the right way, when I replaced the window regulator in a Jeep it all had to come off. Link to comment Share on other sites More sharing options...
mts Posted June 17, 2008 Report Share Posted June 17, 2008 It sure does come off.... all over your clothes Link to comment Share on other sites More sharing options...
ing-schu@online.no Posted June 17, 2008 Report Share Posted June 17, 2008 I'm with MTS on this one. Apply a modest amount of silicone grease (not spray) inside the sliding rails and operate the window untill it runs smooth. Use a cloth wrapped around a screwdriver or something to apply it. Concentrate on areas where the window goes a certain distance. For best access remove the door panel. The bitumen based glue is sticky for sure, but serves a very important role. Plastic left with holes or unstuck somewhere (bottom in particular) when remounting the door panel can result in water leaks into the interior on cars being used. Link to comment Share on other sites More sharing options...
mts Posted June 17, 2008 Report Share Posted June 17, 2008 Yep.... and if you undercoat the car, doors internal especially.... next time you drive with sunroof open... except wonderful fumes coming through holes Link to comment Share on other sites More sharing options...
ing-schu@online.no Posted June 17, 2008 Report Share Posted June 17, 2008 Ahh, the smell of good maintenace Link to comment Share on other sites More sharing options...
mts Posted June 17, 2008 Report Share Posted June 17, 2008 Link to comment Share on other sites More sharing options...
///BHRpowered Posted June 17, 2008 Author Report Share Posted June 17, 2008 I'm sooo damn bored, I'm tempted to unzip the capsule and start on this today Link to comment Share on other sites More sharing options...
mts Posted June 17, 2008 Report Share Posted June 17, 2008 tempted? Your Millenia is ailing and you would rather sit on your ass? SHAME ON YOU. Link to comment Share on other sites More sharing options...
///BHRpowered Posted June 17, 2008 Author Report Share Posted June 17, 2008 incorrect, I have no reason to work on it since it has no plans to be driven right now with the heat and hippies I'm simply bored off my ass Link to comment Share on other sites More sharing options...
SteveSter Posted June 17, 2008 Report Share Posted June 17, 2008 Get an Xbox or Playstation 3... Link to comment Share on other sites More sharing options...
///BHRpowered Posted June 18, 2008 Author Report Share Posted June 18, 2008 playstation is an inferior bootleg stolen redheaded step child, garbage, xbox is just a piece of shit trying to get into the market, and even if the controls, hardware, software, interface, and functions weren't ass retarded stupid, it will never be as good as nintendo because microsoft does not own the rights to any of the great games and or sporting games. Link to comment Share on other sites More sharing options...
SteveSter Posted June 18, 2008 Report Share Posted June 18, 2008 Well out of PS3 and Xbox, ill take the PS3 anyday. Thats what I have and it great on boring days. The nintendo Wii is more for little kids and it is fun to a point. Link to comment Share on other sites More sharing options...
///BHRpowered Posted June 18, 2008 Author Report Share Posted June 18, 2008 incorrect, timeless, though it cannot match SNES Link to comment Share on other sites More sharing options...
ing-schu@online.no Posted June 18, 2008 Report Share Posted June 18, 2008 I can't see neither PS3 nor Wii making your windows go smooth. Get your ass moving if you want to maintain credibility for having the best Millenia in existance. The best Millenia/ Xedos 9 / Eunos 800 award has since long gone to Portugal so you'd better roll up your sleeves. Link to comment Share on other sites More sharing options...
