///BHRpowered Posted August 30, 2008 Report Share Posted August 30, 2008 Today I received a large package from the opposite side of the world, my electronically retractable mirrors sadly the original seller used some weird paper which mildly damaged the paint, but since it wasn't up to bhr spec and is the wrong color it doesn't really matter. I can't turn the mirrors in with my hand like the standard ones and its certainly different, once I find a switch that isn't 200 dollars I will spray some wd-40 in the motor and do a test. Quote Link to comment Share on other sites More sharing options...
latinopikachu Posted August 31, 2008 Report Share Posted August 31, 2008 a switch, you say Quote Link to comment Share on other sites More sharing options...
///BHRpowered Posted August 31, 2008 Author Report Share Posted August 31, 2008 indeed, I have found 2 of them, but the cheapest was 60 dollars, since the us version is only 10 shipped I can't justify it right now, car mods are on the very bottom of the list of where money goes. I'm rather annoyed though, I hooked up the wires in various connections to a 12v supply and couldn't make anything work. Quote Link to comment Share on other sites More sharing options...
latinopikachu Posted August 31, 2008 Report Share Posted August 31, 2008 i hope you didnt fry it Quote Link to comment Share on other sites More sharing options...
///BHRpowered Posted August 31, 2008 Author Report Share Posted August 31, 2008 I don't see how thats possible, I would have had some movement, plus I had it on the lowest setting, wouldn't even power a low beam headlight. there is something its looking for, but I'm not going to take the doors panels off and mess around with it, not until I find a replacement speaker, damn door clips Quote Link to comment Share on other sites More sharing options...
latinopikachu Posted August 31, 2008 Report Share Posted August 31, 2008 well yes but what if you didnt have the polarity right Quote Link to comment Share on other sites More sharing options...
///BHRpowered Posted August 31, 2008 Author Report Share Posted August 31, 2008 once something comes into contact with a millenia it learns its secerts to prevent testing and tampering. I will of course be getting the switch and fully testing everything long before I spend the money to have them painted Quote Link to comment Share on other sites More sharing options...
latinopikachu Posted September 1, 2008 Report Share Posted September 1, 2008 i completely agree with the testing and tampering remember the damn 95 AC display wouldnt work Quote Link to comment Share on other sites More sharing options...
///BHRpowered Posted September 1, 2008 Author Report Share Posted September 1, 2008 indeed, this worries me about the mirrors, the biggest concern is the wiring connector itself, if it doesn't fit then I'm more or less screwed Quote Link to comment Share on other sites More sharing options...
latinopikachu Posted September 1, 2008 Report Share Posted September 1, 2008 :shifty: Quote Link to comment Share on other sites More sharing options...
///BHRpowered Posted September 1, 2008 Author Report Share Posted September 1, 2008 but I'm not taking the door panel off again until I find a replacement speaker, fuckers only come up on ebay once every few months Quote Link to comment Share on other sites More sharing options...
latinopikachu Posted September 1, 2008 Report Share Posted September 1, 2008 go to a junk yard. and find out how to repace the trunk/fuel switch without breaking the damn pegs Quote Link to comment Share on other sites More sharing options...
///BHRpowered Posted September 1, 2008 Author Report Share Posted September 1, 2008 you take off the panel thats how. although now that you mention it, I'm pretty sure mine are broken and I glued it into the speaker grill, if I ever need to remove it I can just connect it at the harnass Quote Link to comment Share on other sites More sharing options...
latinopikachu Posted September 1, 2008 Report Share Posted September 1, 2008 WHAT you admit there is a FLAW with your millenia Quote Link to comment Share on other sites More sharing options...
///BHRpowered Posted September 1, 2008 Author Report Share Posted September 1, 2008 not a flaw at all, the pegs aren't broken, but there are those metal clip...things, which I d'nt don't thinkI could get back on, so its glued and worked much better this way, the connector is there for a reason. The only problem with my millenia is that it has more then 3000 miles on it, I should have just bought 2 and put this on in cold storage Quote Link to comment Share on other sites More sharing options...
Frankzao Posted September 24, 2008 Report Share Posted September 24, 2008 flaw indeed....not OEM..... Quote Link to comment Share on other sites More sharing options...
Troutman Posted September 24, 2008 Report Share Posted September 24, 2008 That trunk/fuel switch is unworkable, I think Mazda glued mine. Quote Link to comment Share on other sites More sharing options...
enginph Posted September 24, 2008 Report Share Posted September 24, 2008 That trunk/fuel switch is unworkable, I think Mazda glued mine. Xedos9 has a solid button for the trunk on the driver door. You have to open it by pressing the button on the trunk.. Cheap mazda, why would they remove such small features and add others.. Quote Link to comment Share on other sites More sharing options...
///BHRpowered Posted September 24, 2008 Author Report Share Posted September 24, 2008 improved OEM Quote Link to comment Share on other sites More sharing options...
latinopikachu Posted September 25, 2008 Report Share Posted September 25, 2008 meh Quote Link to comment Share on other sites More sharing options...
ing-schu@online.no Posted September 25, 2008 Report Share Posted September 25, 2008 That trunk/fuel switch is unworkable, I think Mazda glued mine. Xedos9 has a solid button for the trunk on the driver door. You have to open it by pressing the button on the trunk.. Cheap mazda, why would they remove such small features and add others.. I disagree. Whoever decided that just about all japanese cars should have a trunk opener in the cabin in favour of where you actually need it, behind the car, must have had a bad day. Having to dive inside the car to open the trunk is damn annoying, the pushbutton on the trunklid is one of the Xedos advantages in my opinion. Quote Link to comment Share on other sites More sharing options...
Troutman Posted September 25, 2008 Report Share Posted September 25, 2008 tHERE IS THE KEYFOB. Quote Link to comment Share on other sites More sharing options...
ing-schu@online.no Posted September 25, 2008 Report Share Posted September 25, 2008 Yeah right. The only group of people I can imagine would find an inside trunk opener handy is lazy, screw customer mentality cab drivers. Quote Link to comment Share on other sites More sharing options...
Troutman Posted September 25, 2008 Report Share Posted September 25, 2008 Quote Link to comment Share on other sites More sharing options...
///BHRpowered Posted September 25, 2008 Author Report Share Posted September 25, 2008 generally speaking my trunk was used for 2 purposes (when it was a daily driver) using the keyfob I would put my backpack in during the morning, hit the button when getting out of the car to get it out, it just works, I don't think about it, on my Jeep I have just the handle and no button inside and no button on the key fob. Quote Link to comment Share on other sites More sharing options...
