latinopikachu Posted September 3, 2008 Report Share Posted September 3, 2008 How do you know which one is worn, or what components should be replaced at 120k? My front suspension makes a clunking when going over speed bumps, things like that. The guy who did the alignment said there wasn't anything wrong with it, but I think otherwise. When it's really hot, and you do a hard stop (enough to engage ABS), a terrible creaking/rubbing comes from the right side (sounds like stepping on a creaky wooden floor but very loud). Quote Link to comment Share on other sites More sharing options...
enginph Posted September 3, 2008 Report Share Posted September 3, 2008 You sure its not the motor mount? Quote Link to comment Share on other sites More sharing options...
SteveSter Posted September 3, 2008 Report Share Posted September 3, 2008 The car is just mad because it has the wrong badges. Lol When you change into drive does the engine make the same clunk when it engages into gear? Quote Link to comment Share on other sites More sharing options...
latinopikachu Posted September 3, 2008 Author Report Share Posted September 3, 2008 No. It doesn't clunk when put into gear. It does it over bumps. It's especially noticeable if you go over a big bump like a speed bump very slowly, on the approach when the wheel gets pushed "up" you hear it, and only when it's been driven awhile and it's really hot that it will start making other horrible noises (LH leading link may need to be replaced) Quote Link to comment Share on other sites More sharing options...
mts Posted September 3, 2008 Report Share Posted September 3, 2008 Life up the front, grab onto the wheel with your girly hands at 12 and 6 and try and shake the wheel by alternating pulling with hands. if you can pivot the wheel and replicate the clunk... ball joint is on the way out or gone. At 3 and 9 you can check the steering knuckle.... but this is a Millenia, it will resist you... LOL or fall on your foot... use a jackstand. Quote Link to comment Share on other sites More sharing options...
latinopikachu Posted September 4, 2008 Author Report Share Posted September 4, 2008 The drives side wheel has a tiny, tiny bit of play in and out (as if you're trying to pull the wheel off), and the clunk itself is not replicable but the groaning noise does come from the upper leading link. I plan on doing a full ball joint upper/lower replacement soon, though. Quote Link to comment Share on other sites More sharing options...
mts Posted September 4, 2008 Report Share Posted September 4, 2008 The lateral link is probably gone... Quote Link to comment Share on other sites More sharing options...
latinopikachu Posted September 4, 2008 Author Report Share Posted September 4, 2008 difference between leading/lateral???? Quote Link to comment Share on other sites More sharing options...
enginph Posted September 4, 2008 Report Share Posted September 4, 2008 I plan on doing a full ball joint upper/lower replacement soon, though. Yourself? Quote Link to comment Share on other sites More sharing options...
latinopikachu Posted September 4, 2008 Author Report Share Posted September 4, 2008 no, not myself, unfortunately Quote Link to comment Share on other sites More sharing options...
MazdaMomma Posted September 6, 2008 Report Share Posted September 6, 2008 Life up the front, grab onto the wheel with your girly hands at 12 and 6 and try and shake the wheel by alternating pulling with hands. if you can pivot the wheel and replicate the clunk... ball joint is on the way out or gone. At 3 and 9 you can check the steering knuckle.... but this is a Millenia, it will resist you... LOL or fall on your foot... use a jackstand. I would hope s/he's smart enough to use a jackstand... Quote Link to comment Share on other sites More sharing options...
ing-schu@online.no Posted September 6, 2008 Report Share Posted September 6, 2008 For some reason I associated with items nonrelated to cars when I read the title of this thread... Quote Link to comment Share on other sites More sharing options...
latinopikachu Posted September 8, 2008 Author Report Share Posted September 8, 2008 quiet you. after a thorough testing by a trusted mechanic, the ball joints have been pronounced in good condition. the thing causing the horrible knocking is the $70 strut tower caps/mounts, and the wigglywoggly feeling on very slow turns (eg coming into the driveway) is a whored out $52 bushing for the middle lateral link. all together it will cost me about $400 to have it restored to good condition. Quote Link to comment Share on other sites More sharing options...
enginph Posted September 8, 2008 Report Share Posted September 8, 2008 quiet you. after a thorough testing by a trusted mechanic, the ball joints have been pronounced in good condition. the thing causing the horrible knocking is the $70 strut tower caps/mounts, and the wigglywoggly feeling on very slow turns (eg coming into the driveway) is a whored out $52 bushing for the middle lateral link. all together it will cost me about $400 to have it restored to good condition. Oh man after x's post whatever you write i will read the other way. "Trusted" mechanic testing the balls Check the online dealers, i dont remember them so expensive.. Quote Link to comment Share on other sites More sharing options...
