oderaro Posted April 14, 2009 Report Share Posted April 14, 2009 My 1994 uk xedos 9 2.5 v6 at the moment is acting the same way a car would behave when its about to run out of fuel. Just looking for help on this, also how do i get the codes stored in the car's computer, I have an obd reader but cant find a plug for it under the dash. My car is a 1994 UK mazda xedos 9. It has diagnostic plug under the hood but dont know how to use this either. My car has 108k on the clock.. Ran the car for a good 15 miles over the weekend and it ran fine except when I floor the gas pedal it starts cutting out or spluttering, and I lose power completely; let go of the gas pedal and after a few seconds I can drive on. Also, so long as I depress the gas pedal only slightly all seems ok, but, try half or full throttle and the symptoms I have described above occur! I am totally stumped now.... Any ideas appreciated.. Thanks Quote Link to comment Share on other sites More sharing options...
///BHRpowered Posted April 14, 2009 Report Share Posted April 14, 2009 do you have any warning lights of any kinds? I know its different in europe and I don't believe you have a CEL, and OBD migh be different, xedosman has a xedos9 in europe and could help you more, but based off what your described it might be plugs, ignition coils, maybe even fuel pump. how long have you owned the car and/or have any service records Quote Link to comment Share on other sites More sharing options...
ing-schu@online.no Posted April 14, 2009 Report Share Posted April 14, 2009 There is a method to read the codes via the diagnosis port under the hood, but the easiest is to have a pro read the codes. Look up a thread written by cuto. I think you may have fuel starvation, if it idles and runs normal with little throttle. Clogged fuel filter? Quote Link to comment Share on other sites More sharing options...
oderaro Posted April 15, 2009 Author Report Share Posted April 15, 2009 There is a method to read the codes via the diagnosis port under the hood, but the easiest is to have a pro read the codes. Look up a thread written by cuto. I think you may have fuel starvation, if it idles and runs normal with little throttle. Clogged fuel filter? Thanks. Already had the codes read, there were none. Ok re: Fuel filter; where is it and is there a guide for replacing it? Thanks Oderaro Quote Link to comment Share on other sites More sharing options...
oderaro Posted April 15, 2009 Author Report Share Posted April 15, 2009 do you have any warning lights of any kinds? I know its different in europe and I don't believe you have a CEL, and OBD migh be different, xedosman has a xedos9 in europe and could help you more, but based off what your described it might be plugs, ignition coils, maybe even fuel pump. how long have you owned the car and/or have any service records Haven't owned the car long; it also didn't come with a long service record either. The TCS light did flash when I disconnected the tps so I am assuming that is the CEL ???? Am I wrong on that? Regards Oderaro Quote Link to comment Share on other sites More sharing options...
ing-schu@online.no Posted April 15, 2009 Report Share Posted April 15, 2009 There is a method to read the codes via the diagnosis port under the hood, but the easiest is to have a pro read the codes. Look up a thread written by cuto. I think you may have fuel starvation, if it idles and runs normal with little throttle. Clogged fuel filter? Thanks. Already had the codes read, there were none. Ok re: Fuel filter; where is it and is there a guide for replacing it? Thanks Oderaro I don't know if there is a guide in the technical section, but it is easy enough. 1. Take off the fuelcap. 2.Pull the green relay in the fusebox under the hood, far left when looking backwards. 3. Start the car and run till it stops, which is like 2-3 seconds. Take out the key and for your own safety, disconnect the battery as well. 4. Put the fuelpump relay back in place. You've now depressurized the fuel system. NB. VERY IMPORTANT STEPS! 5. Take out the back seat (not necessary but most convinient). The seatbase is secured by a plastic lever on each side, right between your legs if you sit on each side. Pry the base upwards and they are visible. Then unbolt the seatback, 3 bolts in the bottom IIRC. Then push the back upwards, quite a lot of force is necessary to release the top clamps. 6. Take out or fold back the carpet in the trunk and unbolt the cover in the front part of the trunk. Unless you are less than 5 feet tall you've already discovered why it is convinient to remove the back seat. 7. Do what a man's got to do under said cover. It is abit cramped but less so than if not dismantling said seat. The bolt securing the filter may very well be rusted beyond repair. Try with penetrating rust spray if remotely possible to screw out at all. If not think of an alternative to secure the filter. 8. Turn the socket wrench clockwise and get everything back in place. 9. With everything hooked up again, turn on the ignition and allow fuel pressure to build up before cranking the car, 3-4 seconds will do. Then crank the car and it should start. Good luck! Quote Link to comment Share on other sites More sharing options...
Matt64341 Posted April 15, 2009 Report Share Posted April 15, 2009 When I did mine I did not have the steps/guide to follow, so I did not depressurize the fuel system or take out the rear seat. It ended up being a lot more work than it needed to be without those steps. Next time I am going to do both. Quote Link to comment Share on other sites More sharing options...
enginph Posted April 15, 2009 Report Share Posted April 15, 2009 I waited overnight and there is no pressure.With the seat in place its a lot harder. Quote Link to comment Share on other sites More sharing options...
Matt64341 Posted April 16, 2009 Report Share Posted April 16, 2009 I waited overnight and there is no pressure.With the seat in place its a lot harder. And there is no pass-through on mine, so I had to lay in the trunk. I would never do it that way again. Quote Link to comment Share on other sites More sharing options...
enginph Posted April 16, 2009 Report Share Posted April 16, 2009 I waited overnight and there is no pressure.With the seat in place its a lot harder. And there is no pass-through on mine, so I had to lay in the trunk. I would never do it that way again. If I had to do it through the trunk I would rather pay the shop to do that. Quote Link to comment Share on other sites More sharing options...
latinopikachu Posted April 18, 2009 Report Share Posted April 18, 2009 well, being a short mexican, lat did his though the trunk, yes it was cramped but im not dismantinlg the damn backseat Quote Link to comment Share on other sites More sharing options...
ing-schu@online.no Posted April 18, 2009 Report Share Posted April 18, 2009 It takes like 6 minutes to dismantle, worth it in my book but then I'm 5'10'' and old Quote Link to comment Share on other sites More sharing options...
oderaro Posted April 25, 2009 Author Report Share Posted April 25, 2009 had thecar on a diagnostic machine at last.. Its the mass air flow meter and TPS, anyone know where I can get these in the uk? Thanks all. Quote Link to comment Share on other sites More sharing options...
cuto Posted April 25, 2009 Report Share Posted April 25, 2009 had thecar on a diagnostic machine at last.. Its the mass air flow meter and TPS, anyone know where I can get these in the uk? Thanks all. Get them in germany: try here https://www.atu.de/ersatz-und-verschleisste...-4ws-ta12l-72l/ BTW: i´m good at finding internet parts for xedos ........ Quote Link to comment Share on other sites More sharing options...
ing-schu@online.no Posted April 26, 2009 Report Share Posted April 26, 2009 So there were codes stored after all? My suggestion was based upon issues not causing codes. Anyway, I'm glad to hear the issue is diagnozed. Quote Link to comment Share on other sites More sharing options...
oderaro Posted April 27, 2009 Author Report Share Posted April 27, 2009 thanks that site is in german ! Cant read that... any here in the uk? Thanks Quote Link to comment Share on other sites More sharing options...
cuto Posted April 27, 2009 Report Share Posted April 27, 2009 thanks that site is in german ! Cant read that... any here in the uk? Thanks I can´t read german neither. But just use google to translate the whole website. Best prices and parts for the Xedos are in Germany. Mind you, my search for that air mass flow meter returned only UK junkyards. Quote Link to comment Share on other sites More sharing options...
oderaro Posted April 28, 2009 Author Report Share Posted April 28, 2009 ok water pump has finally died!/? how easy is it to change the water pump?? Quote Link to comment Share on other sites More sharing options...
SteveSter Posted April 28, 2009 Report Share Posted April 28, 2009 Not too bad if you know what your doing and have the right sequence to take everything off. Quote Link to comment Share on other sites More sharing options...
