Troutman Posted January 31, 2012 Report Share Posted January 31, 2012 How would you get the alignment right, probably a tenth of a millimetre wrong would make the light shine a metre in the wrong direction. Quote Link to comment Share on other sites More sharing options...
Frankzao Posted January 31, 2012 Report Share Posted January 31, 2012 Good point. Plus the 95-96 housings are plastic. I am currently dealing with a yellowing issue with my driver's side one. If my 2000 housings are glass, that may be more feasable. Quote Link to comment Share on other sites More sharing options...
///BHRpowered Posted February 1, 2012 Report Share Posted February 1, 2012 97-00 is glass, but a retrofit is much harder. They are adjustable to a small degree up and down but you need to get the rotational angle and left right perfect. What I simply did was park, shine the lights, mark the location then do all work, then repark in EXACT same location and get the alinement to where it needed to be before securing everything into place. now, my retrofit is an extreme custom example. If you did a conventional retrofit into the reflector housings or the 95-96 housings then the buckets will still be adjustable - allowing you to have more room to work with being off Quote Link to comment Share on other sites More sharing options...
Frankzao Posted February 1, 2012 Report Share Posted February 1, 2012 hmmm....either way that requires me to bake them in an oven. Use my stock 00 housings and replace the reflecter housing with a projecter OR use my 95-96 housings and simply "upgrade" the projector. Quote Link to comment Share on other sites More sharing options...
///BHRpowered Posted February 2, 2012 Report Share Posted February 2, 2012 correct. if using 00 housings you would have your choice of shroud, some morito whatever h1's would be probably the only bixenons you could fit, many low beam only options. Quote Link to comment Share on other sites More sharing options...
Frankzao Posted February 3, 2012 Report Share Posted February 3, 2012 The baking is what concerns me Quote Link to comment Share on other sites More sharing options...
enginph Posted February 4, 2012 Author Report Share Posted February 4, 2012 The baking is what concerns me Or your wife? Quote Link to comment Share on other sites More sharing options...
Troutman Posted February 4, 2012 Report Share Posted February 4, 2012 Out of the frying pan and into the fire? Quote Link to comment Share on other sites More sharing options...
Frankzao Posted February 4, 2012 Report Share Posted February 4, 2012 As long as I don't ruin the oven I should be fine. Quote Link to comment Share on other sites More sharing options...
///BHRpowered Posted February 4, 2012 Report Share Posted February 4, 2012 Not really an issue, infact using the glass lenses is much better since glass can take much more heat. The only thing to be careful of is not applying too much pressure to the outer plastic housing as you can warp it. Many posts on hidplanet, generally I like 300 degrees for 8 mins. If you need more do more, just don't start high Quote Link to comment Share on other sites More sharing options...
Frankzao Posted February 5, 2012 Report Share Posted February 5, 2012 Well I'll have to do more research and acquire the parts first Quote Link to comment Share on other sites More sharing options...
///BHRpowered Posted February 5, 2012 Report Share Posted February 5, 2012 hidplanet.com Pretty sure the mositmoto whatever are the only bixenons that will fit into 97-00 housings, but a simple project swap with 95-96 lenses would be quite easy Quote Link to comment Share on other sites More sharing options...
Frankzao Posted February 6, 2012 Report Share Posted February 6, 2012 OK...I am lost. http://www.theretrofitsource.com/index.php?cPath=25 What do you suggest? http://www.theretrofitsource.com/product_i...products_id=227 http://www.theretrofitsource.com/product_i...products_id=237 Or ?????? Quote Link to comment Share on other sites More sharing options...
///BHRpowered Posted February 6, 2012 Report Share Posted February 6, 2012 The H1 morimoto bixenons are the smallest you can get and I THINK will fit the 97-00 housings. I use them in my audi and they are quite excellent. You do not need the entire kit, you can get projectors and the shrouds of your choosing from around 120-130. Then simply use your existing ballasts and pick up some new H1 hid capsules If just doing a swap into 95-96 lenses then you don't need a shroud but get the extra sealant they offer You want these http://www.theretrofitsource.com/product_i...roducts_id=3181 Whatever style you like of these (for 97-00 only) http://www.theretrofitsource.com/index.php?cPath=30 and some of this. http://www.theretrofitsource.com/product_i...products_id=792 Quote Link to comment Share on other sites More sharing options...
