street3890 Posted July 28, 2007 Report Share Posted July 28, 2007 What does it mean to seafome your car? Quote Link to comment Share on other sites More sharing options...
mohamedeladawy@hotmail.com Posted July 28, 2007 Report Share Posted July 28, 2007 do u ever use google? my god man here: http://members.nuvox.net/~on.roz/cars/z28/seafoam.html Quote Link to comment Share on other sites More sharing options...
enginph Posted July 29, 2007 Report Share Posted July 29, 2007 Follow Anubis' post. A better question would be if it is harmful to milly or not. I dont know but I used it for oil, fuel (seafoam), intake manif, and TB (deep creep). I got nothing but performance/ better mpg.. What is your mileage? Quote Link to comment Share on other sites More sharing options...
street3890 Posted July 29, 2007 Author Report Share Posted July 29, 2007 1999 S What do u put into the engine? To make the foam shit lol Quote Link to comment Share on other sites More sharing options...
enginph Posted July 29, 2007 Report Share Posted July 29, 2007 Never heard of a car with 1999 S mileage If you have low mileage (unlikely) it may not make any difference.. Follow the link if not blocked: http://forums.forbidden/index.php?sho...&hl=seafoam edit: ups forbidden.. Quote Link to comment Share on other sites More sharing options...
street3890 Posted July 29, 2007 Author Report Share Posted July 29, 2007 SRY i miss read..thought u said what year is your milly lol i know that weird...I have 88k It's blocked Quote Link to comment Share on other sites More sharing options...
mohamedeladawy@hotmail.com Posted July 30, 2007 Report Share Posted July 30, 2007 u buy a can of seafoam from autozone and u just pour it in there. simple. did it for my rx7. works wonders Quote Link to comment Share on other sites More sharing options...
enginph Posted July 30, 2007 Report Share Posted July 30, 2007 Anubis how many cars do you have? Quote Link to comment Share on other sites More sharing options...
street3890 Posted July 30, 2007 Author Report Share Posted July 30, 2007 Anubis, what's so wonderus about it? What's it actualy do? Quote Link to comment Share on other sites More sharing options...
Mase64 Posted July 30, 2007 Report Share Posted July 30, 2007 i heard its not good.. Quote Link to comment Share on other sites More sharing options...
enginph Posted July 30, 2007 Report Share Posted July 30, 2007 Man you are such a kind. The link describes what it does and they are almost the case with a high mileage car like yours. Adding it to fuel and oil is easy. PVC is risky. Anubis, what's so wonderus about it? What's it actualy do? Mase it was good on mine. I dont think it is bad if done correctly. Quote Link to comment Share on other sites More sharing options...
Graham Posted July 30, 2007 Report Share Posted July 30, 2007 I don't know about this stuff, but with an old car I had a long time ago, I sprayed some "Carbi cleaner" down the throat of it's carby while keeping the revs up enough to keep the motor going. As I sprayed it in, the engine would cough and splutter and all this black stuff came out the exhaust - carbon deposits saying goodbye. End result, more power & better fuel economy. I read a mazda service report the other day that if the Millenia's engine is noisy at startup, that it's carbon deposits on the rings! The procedure to clear it is to fill the cylinders with some fluid and to let it sit for strictly between 5.5 and 6 hours, any longer and it will strip the coating off the pistons! My engine is noisy at startup when cold, so I think I'll find some carby cleaner and try spraying it into my Milly's intake and see what happens G. Quote Link to comment Share on other sites More sharing options...
mohamedeladawy@hotmail.com Posted August 5, 2007 Report Share Posted August 5, 2007 i used to own a milly and now i own a rx7. seafoam is like a realllllly good fuel injector cleaner, head cleaner, clears valve stickiness. just dont use it if it has a high mileage motor as u might remove some deposits that are stopping leakjage. but then again...u should fix those leaks Quote Link to comment Share on other sites More sharing options...
///BHRpowered Posted August 5, 2007 Report Share Posted August 5, 2007 There are 2 general results of seafoam, I have not actually used it so I'm just saying. On most cars it will produce alot of smoke and clean everything out, slightly better mileage, maybe more performance. On high mileage cars (like 135k+) it seems to do alot of harm by cleaning out carbon thats sealing vacumm leaks, which is a pain in the ass. I personally go back and forth if i should use it, the car has low mileage, and my fuel stablizer acts as a mild cleaner as well. Quote Link to comment Share on other sites More sharing options...
street3890 Posted August 5, 2007 Author Report Share Posted August 5, 2007 I have 89k on my milly so idk either!!! Quote Link to comment Share on other sites More sharing options...
///BHRpowered Posted August 5, 2007 Report Share Posted August 5, 2007 no, you'll be fine Quote Link to comment Share on other sites More sharing options...
enginph Posted August 6, 2007 Report Share Posted August 6, 2007 bhr if you use stabilizer all the time seafoam in oil and through intake shouldnt make any difference. As for oil IIRC you use synthetic so it should be clean inside. I wouldnt use it for yours.. But anyway i was like you ended up putting it through all possible holes.. Slightly high mileage? My best was 28ish mpg before seafoam in the oil, after that it went up to 32.4 at the best! An i am getting better mpg now for sure.. Quote Link to comment Share on other sites More sharing options...
Renboy Posted August 6, 2007 Report Share Posted August 6, 2007 <<< Big fan of seafoam. I seldomly run it through the pcv though, just stick to oil and gas and you'll be fine. Quote Link to comment Share on other sites More sharing options...
mts Posted August 6, 2007 Report Share Posted August 6, 2007 I am still confused as to why, when sucked through PCV I got NO smoke.... Quote Link to comment Share on other sites More sharing options...
Renboy Posted August 6, 2007 Report Share Posted August 6, 2007 You wouldn't have the carbon build-up like people that run premium gas since you're burning all of your gas Quote Link to comment Share on other sites More sharing options...
mts Posted August 6, 2007 Report Share Posted August 6, 2007 Quote Link to comment Share on other sites More sharing options...
mohamedeladawy@hotmail.com Posted August 6, 2007 Report Share Posted August 6, 2007 sorry this is offtopic but umm for the 7, i would do 3 tanks of 89 octane and then 91 octane because of the fact that its induction is forced (wow...that sounds weird...anyway!) will it matter if i switch to 87. cuz heh...the prices are kinda getting to me. p.s. i heard that in ontario, the price for a gallon is 4.50!!! wowzerz! Quote Link to comment Share on other sites More sharing options...
enginph Posted August 6, 2007 Report Share Posted August 6, 2007 Unlikely you didnt wait enough (15-30mins) after suck it in.. Quote Link to comment Share on other sites More sharing options...
Renboy Posted August 6, 2007 Report Share Posted August 6, 2007 After the currency conversion and the change to imp.gallon the cost is $3.41 US for a gallon of regular. Quote Link to comment Share on other sites More sharing options...
enginph Posted August 7, 2007 Report Share Posted August 7, 2007 Thanks god ohio is still green http://www.gasbuddy.com/gb_gastemperaturemap.aspx After the currency conversion and the change to imp.gallon the cost is $3.41 US for a gallon of regular. Quote Link to comment Share on other sites More sharing options...
