For My 01-02 S, I've Decided On Navigation
  • Replies 176
Posted Images
where did you mount your antenna? in my altima i had it stuck on metal inside the dash and it worked great, now in my cts, the only place it picks up signal is on the outside of my trunklid, try sticking it on the roof temporarily and see if that picks up the singnal, if not, then you may need a new antenna
Check the connections and power, I know in a millenia when putting a HU back in that tight space things sometimes get just loose enough not to work, The antenna itself is pretty basic technology, it doesn't really stop working unless satalites fall out of the sky or the earths magnetic poles reverse.
I would try sticking it outside, it might also have to be grounded
