bennerz Posted July 11, 2008 Report Share Posted July 11, 2008 I'm trying to install the chitown intake on my milly today, but I can't get the damn driver's side wheel off. I jacked up the car, removed the lug nuts, but it won't budge no matter how hard I pull. I'm getting pretty pissed off and I don't know what else I can do. any ideas? Quote Link to comment Share on other sites More sharing options...
mts Posted July 11, 2008 Report Share Posted July 11, 2008 Once all the nuts are off... make sure you have a jack stand under the car... and give the bottom of the wheel a good kick... usually works for me. Quote Link to comment Share on other sites More sharing options...
SteveSter Posted July 11, 2008 Report Share Posted July 11, 2008 I usually just take all the bolts off but the top one, leave it loose, then raise the car and I use a tube to get some leverage put it under the tire and on the tire at an angle and I kick the tube instead. Its worked for me. Quote Link to comment Share on other sites More sharing options...
///BHRpowered Posted July 11, 2008 Report Share Posted July 11, 2008 a couple good kicks around the wheel should listen it, some people like to hit it outward with a hammer (tire only, not rim) Quote Link to comment Share on other sites More sharing options...
SteveSter Posted July 11, 2008 Report Share Posted July 11, 2008 loosen* BHR I think thats what you meant. Quote Link to comment Share on other sites More sharing options...
///BHRpowered Posted July 11, 2008 Report Share Posted July 11, 2008 actually I like to yell at it first, hasn't gotton a wheel or rotor off yet though Quote Link to comment Share on other sites More sharing options...
Frankzao Posted July 11, 2008 Report Share Posted July 11, 2008 Quote Link to comment Share on other sites More sharing options...
enginph Posted July 11, 2008 Report Share Posted July 11, 2008 I thought loosening all and shake the car a bit before jacking up works. It might be dangerous, idk. Quote Link to comment Share on other sites More sharing options...
///BHRpowered Posted July 12, 2008 Report Share Posted July 12, 2008 ren described this method before, though I don't recommend it, there is no excuse for not being able to get it out without some work. Rotors are far worse Quote Link to comment Share on other sites More sharing options...
mts Posted July 12, 2008 Report Share Posted July 12, 2008 If Ren described it, it is much better than anything BHR would attempt.... I would kill any tire shop that tried to knock my wheel off with a hammer on the rubber.... bad mojo.... as the drooling idiot operating the hammer is 90% sure to hit your rim. Quote Link to comment Share on other sites More sharing options...
///BHRpowered Posted July 12, 2008 Report Share Posted July 12, 2008 his approach was to put the wheel on and the lugnuts fairly loose, not even entirely screwed down, then gun it and hit the brakes hard. You can try it, but I wouldn't do it. Quote Link to comment Share on other sites More sharing options...
mts Posted July 12, 2008 Report Share Posted July 12, 2008 MEH.... not coming off... nuts are still there. Trouble with that theory is you will damage the threads on the studs. What I hated was my BMW had bolts and not studs... made placing the wheel a 3 hand operation... Quote Link to comment Share on other sites More sharing options...
bennerz Posted July 12, 2008 Author Report Share Posted July 12, 2008 well I tried knocking around the edges and it didn't work, so I had to resort to rolling back and forth a few feet with loose lug nuts and it came right off. pics of the milly should be coming today! Quote Link to comment Share on other sites More sharing options...
enginph Posted July 12, 2008 Report Share Posted July 12, 2008 Do the air tools have a torque setting or should the wheels always be tightened with torque wrench? Quote Link to comment Share on other sites More sharing options...
mts Posted July 13, 2008 Report Share Posted July 13, 2008 There are torque specs for wheel bolts... NEVER trust an impact gun like loser mechanics use... they are ONLY for removing unless you have the proper torque bars. Quote Link to comment Share on other sites More sharing options...
///BHRpowered Posted July 13, 2008 Report Share Posted July 13, 2008 what I about mechs is they use an impact wrench to put the bolts on, but then check them with a tq wrench and its already way over Quote Link to comment Share on other sites More sharing options...
mts Posted July 13, 2008 Report Share Posted July 13, 2008 THOSE ARE FUCKING IDIOTS Quote Link to comment Share on other sites More sharing options...
latinopikachu Posted July 13, 2008 Report Share Posted July 13, 2008 agreed Quote Link to comment Share on other sites More sharing options...
SteveSter Posted July 13, 2008 Report Share Posted July 13, 2008 Im training to be an "Automotive Technician" so we dont do crap like that only mechanics do. And yes there is a difference. Quote Link to comment Share on other sites More sharing options...
///BHRpowered Posted July 13, 2008 Report Share Posted July 13, 2008 oh really now? I can promise you that the guys changing the tires at any automotive place, especially sears or whereever are not mechanics, just hourly grease monekys Quote Link to comment Share on other sites More sharing options...
excluesiveonez Posted July 13, 2008 Report Share Posted July 13, 2008 any pics with the new wheels? Quote Link to comment Share on other sites More sharing options...
bennerz Posted July 14, 2008 Author Report Share Posted July 14, 2008 any pics with the new wheels? I didn't get new wheels I was just installing the chitown intake. Quote Link to comment Share on other sites More sharing options...
SteveSter Posted July 14, 2008 Report Share Posted July 14, 2008 Mechanics= Grease Monkeys, Steven= future ASE Certified Autmotive Technician. Mechanics are just part replacers, nothing more. They dont have the skills to really diagnose a problem. Quote Link to comment Share on other sites More sharing options...
enginph Posted July 15, 2008 Report Share Posted July 15, 2008 Mechanics= Grease Monkeys, Steven= future ASE Certified Autmotive Technician. Mechanics are just part replacers, nothing more. They dont have the skills to really diagnose a problem. But they very well know how to charge you for diagnostics Quote Link to comment Share on other sites More sharing options...
Frankzao Posted July 15, 2008 Report Share Posted July 15, 2008 Hey Steve, do they have a reference for a muffler bearing in that book? I've heard of ASE mechanics trying to change one before. What about a piston return spring? Quote Link to comment Share on other sites More sharing options...
