ChiTown Posted September 13, 2008 Report Share Posted September 13, 2008 what brand of stainless steel brake lines would you guys recommend? the goodridge ones are listed for years 95 to 98? will they fit my 2000? i also saw technafit brand or sometin llike that. anyone have a trusted seller or link? i need new pads all around and rear rotors so i might just upgrade everything. where would you guys recommend i buy some drilled rotors? i think i will stick with ceramic padsw and keep the rims clean for now. Quote Link to comment Share on other sites More sharing options...
ChiTown Posted September 13, 2008 Author Report Share Posted September 13, 2008 another thing. does anyone have the millys part # list in a pdf format? why hasnt someone copied a part number list yet? is there a different part number for the front R/L upper link? thos got to get replaced too. thanx for the help. Quote Link to comment Share on other sites More sharing options...
///BHRpowered Posted September 13, 2008 Report Share Posted September 13, 2008 chitown - information like that can be guarded at times, we have a really hard time finding oem part numbers for anything. My question has always been you can search by part number and aftermarket companies know what matches...so there must be a reverse database somewhere. As for your question, I got my SS line from corksport and were corksport brand, tirerack and horsepowerfreaks have kits for the millenia, I would highly recommend the x-drilled KVR rotors, and upgrading the front pads, keep the rear stock. Quote Link to comment Share on other sites More sharing options...
ChiTown Posted September 14, 2008 Author Report Share Posted September 14, 2008 chitown - information like that can be guarded at times, we have a really hard time finding oem part numbers for anything. My question has always been you can search by part number and aftermarket companies know what matches...so there must be a reverse database somewhere. As for your question, I got my SS line from corksport and were corksport brand, tirerack and horsepowerfreaks have kits for the millenia, I would highly recommend the x-drilled KVR rotors, and upgrading the front pads, keep the rear stock. tirerack doesnt carry the lines anymore. horsepower freaks has the techna fit ones. kvrperformance.com sells their lines "goodridge tested". just need to know which ones to get, i heard there were some issues with install with the goodridge ones but me no fo sho. are your kvr rotors coated, i found two places to purchase them but no option to get them coated... Quote Link to comment Share on other sites More sharing options...
DoN_BLaZe34 Posted September 14, 2008 Report Share Posted September 14, 2008 chi I have some brand new X-drilled rotors I bought for my millenia but they didn't fit b/c the 01/02's have larger sized rotors..the hubs have been painted silver...not sure if u'd be interested Quote Link to comment Share on other sites More sharing options...
///BHRpowered Posted September 14, 2008 Report Share Posted September 14, 2008 yes, mine are plated silver www.performancerotors.com, might also carry brake lines. There isn't anything special about the lines, there just cut to a certain lenght and thats about it, brand shouldn't matter Quote Link to comment Share on other sites More sharing options...
Renboy Posted September 14, 2008 Report Share Posted September 14, 2008 Goodridge have been known to crack and leak, not to mention ken inn had problems installing them where the bend in the line was tighter than one would want. I would try the technafit before going goodridge. Quote Link to comment Share on other sites More sharing options...
///BHRpowered Posted September 14, 2008 Report Share Posted September 14, 2008 how they bend or crack, thats one of the main reasons you get, stainless STEEL brake lines Quote Link to comment Share on other sites More sharing options...
ChiTown Posted September 14, 2008 Author Report Share Posted September 14, 2008 chi I have some brand new X-drilled rotors I bought for my millenia but they didn't fit b/c the 01/02's have larger sized rotors..the hubs have been painted silver...not sure if u'd be interested thanks but i think i will just go cheap with everything for now. i am going to replace the rear rotors and pads only and skip any performance upgrades for now, winter is almost here anyway, and now my horn doesnt work...its always somethin. the fuse is still good, goin to test the relay right now...................... Quote Link to comment Share on other sites More sharing options...
Renboy Posted September 14, 2008 Report Share Posted September 14, 2008 how they bend or crack, thats one of the main reasons you get, stainless STEEL brake lines You get stainless brake lines because they don't swell, thus more pressure goes to the piston in the caliper. All braided lines have a coating on the outside, that coating is what cracks. And if they didn't bend then they would break every time there was a change in suspension position. Again, common sense. Quote Link to comment Share on other sites More sharing options...
latinopikachu Posted September 14, 2008 Report Share Posted September 14, 2008 common sense and bhr in the same sentence? Quote Link to comment Share on other sites More sharing options...
enginph Posted September 14, 2008 Report Share Posted September 14, 2008 how they bend or crack, thats one of the main reasons you get, stainless STEEL brake lines You get stainless brake lines because they don't swell, thus more pressure goes to the piston in the caliper. All braided lines have a coating on the outside, that coating is what cracks. And if they didn't bend then they would break every time there was a change in suspension position. Again, common sense. I guess he thinks ss lines are tougher and they dont bend at all Quote Link to comment Share on other sites More sharing options...
///BHRpowered Posted September 14, 2008 Report Share Posted September 14, 2008 and once again ren is living in the 70's SS lines are plastic lines with a SS wrap around it, more or less, plastic lines break because they swell and they can't take it, the SS reenforces everything, so yes more goes to the pedal, but modern lines hardly swell at all, and when was the last time you heard about someone slamming on the brakes and a line bursting...oh right never, up until the 80's it was quite common. Quote Link to comment Share on other sites More sharing options...
latinopikachu Posted September 15, 2008 Report Share Posted September 15, 2008 lmfao Quote Link to comment Share on other sites More sharing options...
Renboy Posted September 15, 2008 Report Share Posted September 15, 2008 and once again ren is living in the 70's SS lines are plastic lines with a SS wrap around it, more or less, plastic lines break because they swell and they can't take it, the SS reenforces everything, so yes more goes to the pedal, but modern lines hardly swell at all, and when was the last time you heard about someone slamming on the brakes and a line bursting...oh right never, up until the 80's it was quite common. Women on average say 6000 words in a day, men only 3000. For someone that apparently dislikes women you sure seem to act like one. You don't know anything but keep on talking. Either you're a hermaphrodite or lat's not the only 'different' one on the site. ALL stainless brake lines have a coating on the outside that is some form of plastic, and it can crack. Given a stainless steel braid is not water tight, the plastic/rubber on the inside of the braid does the sealing, the braid prevents swelling, and the outside protects the braid from wearing. If the plastic breaks, which does happen, and the braid rubs through then the fluid runs out. I've read a few times that goodridge lines are no good. Instead of spewing your stupidity and putting someone's life at risk, shut the fuck up and let people who know what they're talking about give advice. Quote Link to comment Share on other sites More sharing options...
SteveSter Posted September 15, 2008 Report Share Posted September 15, 2008 BHR its really no use to argue these things with someone who works in this field and has done it for alot longer than anyone here. I have yet to see Ren be wrong about something so maybe you should start to believe him when he says something. Just a suggestion. Quote Link to comment Share on other sites More sharing options...
///BHRpowered Posted September 15, 2008 Report Share Posted September 15, 2008 ren would make a damn good 5.9 owner and love there circle jerks, but as usual with anything outside 70's technology he's wrong. If the above mentioned brake lines are cracking under cold or whatever then its shitty plastic combined with faulty SS, but more then likely just bad connections. Quote Link to comment Share on other sites More sharing options...
enginph Posted September 15, 2008 Report Share Posted September 15, 2008 BHR its really no use to argue these things with someone who works in this field and has done it for alot longer than anyone here. I have yet to see Ren be wrong about something so maybe you should start to believe him when he says something. Just a suggestion. Dude, this forum is just to keep BHR from writing in other forums. And it is not open to search engines so nobody can find the posts here. What are we doing here? Every prison needs some guardians Quote Link to comment Share on other sites More sharing options...
Renboy Posted September 15, 2008 Report Share Posted September 15, 2008 ren would make a damn good 5.9 owner and love there circle jerks, but as usual with anything outside 70's technology he's wrong. If the above mentioned brake lines are cracking under cold or whatever then its shitty plastic combined with faulty SS, but more then likely just bad connections. You drive a jeep with a pushrod engine. If you consider Henry Ford's original design technologically advanced, then even at 70's technology I'm on the moon and you light your house with candles. And no, I'm not a dyslexic white American whose house resembles a bus, and consider returning empty bud light bottles as an income subsidy. I will never be on a Jeep forum. Quote Link to comment Share on other sites More sharing options...
Synesthesia Posted September 15, 2008 Report Share Posted September 15, 2008 Dude, this forum is just to keep BHR from writing in other forums. And it is not open to search engines so nobody can find the posts here. What are we doing here? Every prison needs some guardians The water cooler is the only section which cannot be searched or accessed by non members, along with some of the tech areas other members paid money for. Otherwise anyone can search these forums - But if you think this forum keeps BHR from posting eles where you do not know BHR. He still whores Jeepsunlimited, audiworld, novajeepers, and maybe even bimmerforums. Last time I checked he's averaging 5-7k a year at JU alone. Quote Link to comment Share on other sites More sharing options...
dwmcqueen Posted February 21, 2009 Report Share Posted February 21, 2009 Not to give life to an old topic - but has anyone here installed stainless steel brake lines on a 2001 - 2002? All parts I find online are for the earlier years... Quote Link to comment Share on other sites More sharing options...
///BHRpowered Posted February 21, 2009 Report Share Posted February 21, 2009 should be exactly the same, nothing special other then the lenght, and lenght should be same Quote Link to comment Share on other sites More sharing options...
dwmcqueen Posted February 21, 2009 Report Share Posted February 21, 2009 I agree with you BHR - though I am curious why all are speced for 00 and under....I know some of the rotors are different on the 2002 - so if I buy a normal kit, would I be okay? Quote Link to comment Share on other sites More sharing options...
///BHRpowered Posted February 21, 2009 Report Share Posted February 21, 2009 cheap ebay rotors are different, but calipers are all the same. There are lots of parts that are lised for 95-00, or "L" or "S" only, yet work just fine. I got mine from corksport years ago and I swear they said 95-02, a real shame they stopped carrying the millenia Quote Link to comment Share on other sites More sharing options...
enginph Posted February 21, 2009 Report Share Posted February 21, 2009 I think even for 95-00 there are some issues with length. Are you gonna install yourself? I am thinking about it nowadays. My pedal is not rock solid anymore after 120k miles.. Quote Link to comment Share on other sites More sharing options...
