Hid Kits
enginph
  • Replies 188
Well they were plug n play so to speak....the kit had a harness that connected to my bulb harness and another for the bulbs. The thin capacitors didn't fit in the housing so I drill a hole in the caps and ran the wires in and out of the housing leaving the capacitor thingies mounted on the outside. Want pics?
I remember seeing wires running from your battery. I should be wrong nevermind. I bought wiring harness to run from battery.
That is 1 reason but the primary reason is ballasts are very sensitive, if hooked into factory wiring the ballasts are down the roadin terms of power, you hit brakes, have a system, whatever it all drains power.
Connecting them directly to the battery means it gets first dibs
I read some cars develop statics on the radio after installing HIDs. Thats the ballast's 450Hz tones mixing into headunit. A direct connection to battery should solve this issue.
MARKER LIGHTS!!!!
There is no such thing as parking lights, to use retarded honda google terms make you look like both a fool and a democrat.
You don't turn on lights after you've parked, or to park or anything, there called MARKER lights
I turn on the parking lights whenever I decide to park, to let people know I am gonna park.
parking light
(plural park·ing lights)
noun
small light on vehicle: either of the two small lights on a motor vehicle used in conditions where light is poor, but not poor enough to warrant the use of headlights
Microsoft® Encarta® 2007. © 1993-2006 Microsoft Corporation. All rights reserved.
No you don't, and why the fuck wouldyou let them know? your suppose to put on a TURN signal, if someone turned on there marker lights approaching a space it would mean nothing and id park there.
seriously, tyhe several tons of reflective metal slowing and turning doesn't tip them off? in a location that is purpose built for the parking of cars
MARKER LIGHTS!!!!
National Highway Traffic Safety Administration calls them parking lights.
http://edocket.access.gpo.gov/cfr_2004/oct...9cfr571.108.pdf
http://en.wikipedia.org/wiki/Automotive_li...anding_lamps.29
Nighttime standing-vehicle conspicuity to the front is provided by "front position lamps",[15] known as "parking lamps" or "parking lights" in North America,[5] and "front sidelights" in British English.[19] Despite the UK term, these are not the same as the sidemarker lights described below. The front position lamps may emit white or amber light in North America;[5] elsewhere in the world they must emit only white light.[15] Colloquial city light terminology for front position lamps[20] derives from the practice, formerly adhered to in cities like Moscow, London and Paris, of driving at night in built-up areas using these low-intensity lights rather than headlamps.[21] It is now illegal in many countries to drive a vehicle with parking lamps illuminated, unless the headlamps are also illuminated. The UK briefly required Dim-Dip lights, described below, in an attempt to optimise the level of light used at night in built-up areas.
