AngelOfDeath Posted November 16, 2006 Report Share Posted November 16, 2006 Ok well since 2 days ago, my milly is making a squeaking sound/whinning sound from my passanger side back wheel. I went to Tires Plus to get an oil change and I mention it to them that somewhere on the passanger sound I am hearing it. I go bakc and they said nothing is wrong and there is not brake problems. What could this be??? It's alot worse when I am turning the car. Ideas anyone? Quote Link to comment Share on other sites More sharing options...
///BHRpowered Posted November 16, 2006 Report Share Posted November 16, 2006 I'm not sure what effect turning would have since the wheels do not turn, but I certainly would have said to check the brakes first. Does the sound go away slightly when your on the brakes? Quote Link to comment Share on other sites More sharing options...
AngelOfDeath Posted November 16, 2006 Author Report Share Posted November 16, 2006 not really it happens when I drive 1. really slow 2. press on my brakes 3. turning. The brakes should be fine thought. Tires Plus checked them " your brakes are good,nothing wrong with them." So I am lost what it could be Quote Link to comment Share on other sites More sharing options...
Synesthesia Posted November 16, 2006 Report Share Posted November 16, 2006 hmm, I would say a cv joint, but you say its coming from the rear.... Quote Link to comment Share on other sites More sharing options...
mts Posted November 17, 2006 Report Share Posted November 17, 2006 Maybe a bad wheel bearing? Allowing the hub to shift when turning and the brakes coming into contact and squealing? Did they rotate your wheels? Maybe the guard on the brakes is too close to the disk? Quote Link to comment Share on other sites More sharing options...
AngelOfDeath Posted November 17, 2006 Author Report Share Posted November 17, 2006 they did rotate my tires but the sound was there before they did that. It's not as bad as before. "Maybe the guard on the brakes is too close to the disk?" how would I tell about this?? Quote Link to comment Share on other sites More sharing options...
mts Posted November 17, 2006 Report Share Posted November 17, 2006 Jack up the car, take the wheel off and check it. spinning the disk to see if the noise is made. Quote Link to comment Share on other sites More sharing options...
ing-schu@online.no Posted November 17, 2006 Report Share Posted November 17, 2006 Might be gravel (small rocks) stuck between disc and splashguard, caliper or pads. Or simply the wear indicators. I'd also check the handbrake liners, might not clear the drums due to partially stuck wires or mechanism. MTS suggested the right method to find it if that's the case. Wheel bearings usually makes a grinding noise most evident inside the car while driving, often hard to spot which wheel, up front in particular. Quote Link to comment Share on other sites More sharing options...
MazdaMomma Posted November 18, 2006 Report Share Posted November 18, 2006 That kind of squeeling noise on mine was the brake shield. It was bent. I replaced it for like $40. Dealer installed cause I didn't know how. Quote Link to comment Share on other sites More sharing options...
AngelOfDeath Posted November 26, 2006 Author Report Share Posted November 26, 2006 Thanks guys Quote Link to comment Share on other sites More sharing options...
mohamedeladawy@hotmail.com Posted November 28, 2006 Report Share Posted November 28, 2006 has this been solved? Quote Link to comment Share on other sites More sharing options...
///BHRpowered Posted November 28, 2006 Report Share Posted November 28, 2006 unclear Quote Link to comment Share on other sites More sharing options...
mohamedeladawy@hotmail.com Posted November 29, 2006 Report Share Posted November 29, 2006 has the rx7 come in yet? Quote Link to comment Share on other sites More sharing options...
AngelOfDeath Posted December 6, 2006 Author Report Share Posted December 6, 2006 sorry guys...no there is still squeaking goin on. Getting pissed off and about to just have the damn thing serviced. CAmel- The rx is in and been working on it. I have been added parts and cleaning the engine bay. Right now the is sitting very nice and pretty. Will post pictures in the rx-7 forum shortly. Quote Link to comment Share on other sites More sharing options...
mts Posted December 6, 2006 Report Share Posted December 6, 2006 Dust shield on the brakes touching? Squeaky strut? Stop running over cats. Quote Link to comment Share on other sites More sharing options...
AngelOfDeath Posted December 6, 2006 Author Report Share Posted December 6, 2006 HAHAHA it 's not cats its the fact that the roads n gainesville suck major ass and there is always construction so crap is all over the road and the roads have pot holes. In s.fl roads were never this bad. Quote Link to comment Share on other sites More sharing options...
AngelOfDeath Posted December 7, 2006 Author Report Share Posted December 7, 2006 UPDATE: problem is fixed. About $558.02 later. The rotor and brakes went bad when some guy in a construction truck dropped metal piping in front of me. Other than that the Milly is not at top notch shape. NOw I need to find that bastard that caused this and , to him. Quote Link to comment Share on other sites More sharing options...
mts Posted December 7, 2006 Report Share Posted December 7, 2006 That sucks dude.... the pipes only hit the brakes? Quote Link to comment Share on other sites More sharing options...
AngelOfDeath Posted December 7, 2006 Author Report Share Posted December 7, 2006 brakes and scratched up the undercage and that was it. I avoided the pipes flying at me. Luckly I got away from one that was 1 foot away from my windshield. Quote Link to comment Share on other sites More sharing options...
mts Posted December 8, 2006 Report Share Posted December 8, 2006 WOW lucky. Quote Link to comment Share on other sites More sharing options...
AngelOfDeath Posted December 8, 2006 Author Report Share Posted December 8, 2006 thats what I am saying Quote Link to comment Share on other sites More sharing options...
MazdaMomma Posted December 9, 2006 Report Share Posted December 9, 2006 Wow! Damn lucky. And another prayer of safety for the milli drivers answered.... Quote Link to comment Share on other sites More sharing options...
AngelOfDeath Posted December 9, 2006 Author Report Share Posted December 9, 2006 yep! the milly saved me .... if I was in the 7 I dunno what would of happen. Quote Link to comment Share on other sites More sharing options...
MazdaMomma Posted December 10, 2006 Report Share Posted December 10, 2006 I know if Gotta and his girl were in another car when he flipped it on it's roof, I don't think they would have escaped with nary a scratch Quote Link to comment Share on other sites More sharing options...
AngelOfDeath Posted December 10, 2006 Author Report Share Posted December 10, 2006 I will say this the milly is a safe car. I like have the side air bags. Quote Link to comment Share on other sites More sharing options...
