mts Posted January 17, 2007 Report Share Posted January 17, 2007 http://www.performancecenter.com/product.p...ic+Applications http://www.performancecenter.com/product.p...ic+Applications Quote Link to comment Share on other sites More sharing options...
DoN_BLaZe34 Posted January 17, 2007 Report Share Posted January 17, 2007 yes, do it Quote Link to comment Share on other sites More sharing options...
excluesiveonez Posted January 17, 2007 Report Share Posted January 17, 2007 get eibach or H&R..... fuk that b&g.. i'd say go H&R! Quote Link to comment Share on other sites More sharing options...
mts Posted January 17, 2007 Author Report Share Posted January 17, 2007 I have to get new wheels first off... and in the spring the suspension is getting done. Quote Link to comment Share on other sites More sharing options...
DoN_BLaZe34 Posted January 17, 2007 Report Share Posted January 17, 2007 lol i say eibach... Quote Link to comment Share on other sites More sharing options...
mts Posted January 17, 2007 Author Report Share Posted January 17, 2007 I have a line on 8 wheels right now... 4 winters on steels, and 4 Ultra Highs on MSR 17" rims dark and polished lips... all with great rubber for $1200 like this... Quote Link to comment Share on other sites More sharing options...
DoN_BLaZe34 Posted January 17, 2007 Report Share Posted January 17, 2007 what are the winter on steels Quote Link to comment Share on other sites More sharing options...
mts Posted January 17, 2007 Author Report Share Posted January 17, 2007 Look like Michelin Alpins on 16s I have only seen pics... but should be able to get a look this weekend. Quote Link to comment Share on other sites More sharing options...
DoN_BLaZe34 Posted January 17, 2007 Report Share Posted January 17, 2007 if u're looking for winter wheels, i'd sell u my 16's... Quote Link to comment Share on other sites More sharing options...
///BHRpowered Posted January 17, 2007 Report Share Posted January 17, 2007 those rims in the picture are ghetto. however I strongly recommend going with the eibach or h&r Quote Link to comment Share on other sites More sharing options...
mts Posted January 17, 2007 Author Report Share Posted January 17, 2007 That is your opinion... and you only like silvers... so it is taken as such... Quote Link to comment Share on other sites More sharing options...
AngelOfDeath Posted January 17, 2007 Report Share Posted January 17, 2007 those rims in the picture are ghetto. however I strongly recommend going with the eibach or h&r agreed! Quote Link to comment Share on other sites More sharing options...
DoN_BLaZe34 Posted January 17, 2007 Report Share Posted January 17, 2007 my offer still stands mts Quote Link to comment Share on other sites More sharing options...
Super S 69 Posted January 17, 2007 Report Share Posted January 17, 2007 I have to get new wheels first off... and in the spring the suspension is getting done. Upgrade the shock cause the lowered spring is gonna murder it. Quote Link to comment Share on other sites More sharing options...
///BHRpowered Posted January 18, 2007 Report Share Posted January 18, 2007 There are no aftermarket struts for the millenia, if you have over 50k on the existing shocks it is a good idea to replace them with oem ones Quote Link to comment Share on other sites More sharing options...
Troutman Posted January 18, 2007 Report Share Posted January 18, 2007 I believe there are aftermarket rear shocks, but they are very hard. The normal way is to use stock dampers and change them a bit more regularly. Even the Eunos 800M SP did this. Quote Link to comment Share on other sites More sharing options...
Super S 69 Posted January 18, 2007 Report Share Posted January 18, 2007 There are no aftermarket struts for the millenia, if you have over 50k on the existing shocks it is a good idea to replace them with oem ones i see Quote Link to comment Share on other sites More sharing options...
///BHRpowered Posted January 18, 2007 Report Share Posted January 18, 2007 koni makes aftermarket ones yes, now you CAN retrofit others, but it gets costly Quote Link to comment Share on other sites More sharing options...
Super S 69 Posted January 18, 2007 Report Share Posted January 18, 2007 koni makes aftermarket ones yes, now you CAN retrofit others, but it gets costly When done right its worth it. No premature tire wear needed Quote Link to comment Share on other sites More sharing options...
ing-schu@online.no Posted January 18, 2007 Report Share Posted January 18, 2007 Actually KYB makes the aftermarket rear ones, theyre named GR2 and works great, I found them better than stock actually. Great deal, being half the price here. They're NOT hard or harsh at all, but I think they have slightly more rebound damping which did my Xedos good anyway, more refined ride over large bumps Quote Link to comment Share on other sites More sharing options...
DoN_BLaZe34 Posted January 18, 2007 Report Share Posted January 18, 2007 i didn't/don't think they could be used on the newer models... Quote Link to comment Share on other sites More sharing options...
ing-schu@online.no Posted January 18, 2007 Report Share Posted January 18, 2007 They're supposed to fit 95-96, but fit my 00 perfectly. I wouldn't know about the 01-02's though. Quote Link to comment Share on other sites More sharing options...
Frankzao Posted January 18, 2007 Report Share Posted January 18, 2007 What about '97? Quote Link to comment Share on other sites More sharing options...
DoN_BLaZe34 Posted January 18, 2007 Report Share Posted January 18, 2007 more than likely, they'd fit Quote Link to comment Share on other sites More sharing options...
ing-schu@online.no Posted January 19, 2007 Report Share Posted January 19, 2007 Indeed, but to be sure check this; take off the rear shelf, and measure the thread diametre on top of the pistons. Apparently this is the thing differing. The KYB's have 10 mm threads, just like the stock ones in my 00 Xedos. The piston diametre is 12 mm, also like the stock ones. On some cars there is apparently 12 mm threads, which would cause a need for milling a bush to make them fit. No major obstacle in my book. There is one difference though, which is also a minor obstacle. The lower spring holder on the KYB shock is turned 180 degrees compared to the ABS sensor wire braquet. Therefore the spring will have to be turned 180 degrees to fit, which is no problem, as the top rubbermount is free to spin. Routing the ABS wire on the other side of the strut is another option. I chose the first option. And my Xedos is running great with the KYB's. Quote Link to comment Share on other sites More sharing options...
