Dallasaurora Posted January 24, 2007 Report Share Posted January 24, 2007 I've recently discovered my low beams aren't working. I changed the fuse and replaced the HB4s and still nothing. Everything else works fine...it's just the low beams that don't come on. What could it be ? Quote Link to comment Share on other sites More sharing options...
Troutman Posted January 24, 2007 Report Share Posted January 24, 2007 Is the relay clicking correctly when turned on? Quote Link to comment Share on other sites More sharing options...
ing-schu@online.no Posted January 24, 2007 Report Share Posted January 24, 2007 Were the fuse blown? I agree with Trout, check the relay without starting the engine, just switching on the ignition with the light switch on should make you able to detect if the relay is kicking in, but there are several doing the same, find which one and put a finger on it while someone else is turning on the ignition. Personally I'd suspect a virus spread from other vehichles in the driveway Quote Link to comment Share on other sites More sharing options...
mts Posted January 24, 2007 Report Share Posted January 24, 2007 Dirty contacts on the switch, loose wires on the back of the switch? Quote Link to comment Share on other sites More sharing options...
Dallasaurora Posted January 24, 2007 Author Report Share Posted January 24, 2007 Where is the relay for the low beams. That was the first thing I tried and never heard no click. You just couldn't resist that dig could you ? Quote Link to comment Share on other sites More sharing options...
mohamedeladawy@hotmail.com Posted January 24, 2007 Report Share Posted January 24, 2007 i have a similar problem with the fogs. but only one turns on. could be the bulb havent checked Quote Link to comment Share on other sites More sharing options...
///BHRpowered Posted January 25, 2007 Report Share Posted January 25, 2007 dallas, it sounds like either the relay or fuse,if you have put in some higher wattage bulbs lately you may simply need to up the amp rating on the fuse, if it blew again. if the fuse blows I think nothing but the highbeams will work, no markers, no fogs etc Quote Link to comment Share on other sites More sharing options...
Dallasaurora Posted January 25, 2007 Author Report Share Posted January 25, 2007 Like I said, I replaced the bulbs and the fuse but still no low beams. Everything else works; side lights, fogs and high beams. Where is the relay located ? Quote Link to comment Share on other sites More sharing options...
ing-schu@online.no Posted January 25, 2007 Report Share Posted January 25, 2007 I can look into the location this afternoon. Though there are some 12 degrees C below Zero as we speak... Actually popping out and back in all the relays under the left side fuse cover might be a good start, a bad connection could be the cause. Even quite likely, bad connections are responsible for a huge part of all electrical trouble. Electrones missing their goal, see. And yes, I couldn't resist Quote Link to comment Share on other sites More sharing options...
mts Posted January 25, 2007 Report Share Posted January 25, 2007 i have a similar problem with the fogs. but only one turns on. could be the bulb havent checked Could be a dirty ground wire.... dallas, it sounds like either the relay or fuse,if you have put in some higher wattage bulbs lately you may simply need to up the amp rating on the fuse, if it blew again. if the fuse blows I think nothing but the highbeams will work, no markers, no fogs etc High wattage bulbs are know to melt the plugs off the back... Mazda uses the cheapest plugs available. Quote Link to comment Share on other sites More sharing options...
ing-schu@online.no Posted January 25, 2007 Report Share Posted January 25, 2007 High wattage bulbs are know to melt the plugs off the back... Mazda uses the cheapest plugs available. I think you are wrong there sir. Ever heard of french car electrics? Quote Link to comment Share on other sites More sharing options...
mts Posted January 25, 2007 Report Share Posted January 25, 2007 Everything I pulled out of my Milly is from Japan.... and some cheap ass shit. Quote Link to comment Share on other sites More sharing options...
mohamedeladawy@hotmail.com Posted January 25, 2007 Report Share Posted January 25, 2007 he is saying that french cars have even cheaper plastics than mazda. Quote Link to comment Share on other sites More sharing options...
mts Posted January 25, 2007 Report Share Posted January 25, 2007 DOH... I think Jaguar had that cornered for the longest time... Quote Link to comment Share on other sites More sharing options...
///BHRpowered Posted January 25, 2007 Report Share Posted January 25, 2007 if you hear a clicking sound when turning the lights on its most likely a relay, you may need to open the hood and listen while someone eles turns on the lights. Dallas, are you running any aftermarket lights or hid's? I could have sworn you had just regular bulbs and no modifictions Quote Link to comment Share on other sites More sharing options...
mohamedeladawy@hotmail.com Posted January 25, 2007 Report Share Posted January 25, 2007 he just has regular bulbs. its just that his low beams dont work anymore Quote Link to comment Share on other sites More sharing options...
Dallasaurora Posted January 25, 2007 Author Report Share Posted January 25, 2007 Yes, Nub is correct. Quote Link to comment Share on other sites More sharing options...
ing-schu@online.no Posted January 25, 2007 Report Share Posted January 25, 2007 Flip off the fuse cover in the engine compartment. The headlight relay should be the third on the second row of relays, counting from left to right, and rear to forward. It should be green. Try to take it out and check for corroded or melted connections. Put it back in and ask someone to turn the ignition on while holding a finger on it, should be possible to spot if it is working or not. Another good'ol trick is to try to switch two similar relays, to see if you get another item not working. For instance relay no 6 on the first row, rear window defroster. If they are similar connectors that is. Sorry, too cold to dig deep into the issue on my car tonight Quote Link to comment Share on other sites More sharing options...
mohamedeladawy@hotmail.com Posted January 25, 2007 Report Share Posted January 25, 2007 well done x-man! Quote Link to comment Share on other sites More sharing options...
ing-schu@online.no Posted January 25, 2007 Report Share Posted January 25, 2007 Not really, just a quick look in my owners manual added up with a dose of trained electricial troubleshooting. Quote Link to comment Share on other sites More sharing options...
mohamedeladawy@hotmail.com Posted January 26, 2007 Report Share Posted January 26, 2007 better than most ppl here Quote Link to comment Share on other sites More sharing options...
mts Posted January 26, 2007 Report Share Posted January 26, 2007 MEH... NUB clean your ground wires... Quote Link to comment Share on other sites More sharing options...
ing-schu@online.no Posted January 26, 2007 Report Share Posted January 26, 2007 Like a faulty ground wire would cause ONLY the headlights from working? Sure, very likely. But of course, wouldn't hurt checking. My experience on japanese cars though, I have never had one single faulty ground connection EVER. Quote Link to comment Share on other sites More sharing options...
mts Posted January 27, 2007 Report Share Posted January 27, 2007 Sure would... been there done that... Quote Link to comment Share on other sites More sharing options...
ing-schu@online.no Posted January 27, 2007 Report Share Posted January 27, 2007 Dallas, how is your troubleshooting turning out? Time for update! Quote Link to comment Share on other sites More sharing options...
