Leds
ChiTown
  • Replies 514
For gauges I have the 3-LED #74 you should see higher up on this page, plus regular 5-LED 194s (the older non-SMT ones) which are amply bright. The gauges are the same as the Millenia so this would work for you...
For doors I'm using the high power 194 with heatsink you posted earlier. Yes there's a hotspot but it works...
26 mm is 1mm smaller than a stock 194 according to Autolumination.
Bulb #: 194
Voltage: 12-14 volts
Power: 3-4 watts
Current: .25 amps
Base : Wedge, T10 (T3-1/4)
Globe: Small-round 3/8" dia (10mm)
Overall height: 1-1/16" (27mm)
Description: Glass
According to mazda, 5led from warden touches to the speed gauge, thats why they didnt wanna put them in.
This one gives blueish white, doesnt look good my bro told:
I'd only use like with like personally, that means old fashioned 5-LED 194s with 3-LED #74s. If you found a high power #74 then the high power 194s might suit.
You won't find much, if anything, that is not a cold white colour. It happens the Eunie had blue-tinted bulbs stock anyway so it is no problem here.
