mts Posted May 8, 2008 Report Share Posted May 8, 2008 http://www.andysautosport.com/mazda/1995_1...ay_bars/eibach/ http://www.andysautosport.com/mazda/1995_1...ension/springs/ WEBSITE http://www.andysautosport.com/mazda/1995_1...ia/#PERFORMANCE Link to comment Share on other sites More sharing options...
mts Posted May 8, 2008 Author Report Share Posted May 8, 2008 KYB and OEM shocks. http://www.racepages.com/parts/shocks/mazda/millenia.html Link to comment Share on other sites More sharing options...
mts Posted May 8, 2008 Author Report Share Posted May 8, 2008 EVEN more parts.... http://www.speedyperformanceparts.com/perf...No=0&Npp=10 Link to comment Share on other sites More sharing options...
mts Posted May 8, 2008 Author Report Share Posted May 8, 2008 WHEELS and lights... http://shop.wheelsrims.net/search.html?mak...&part_type= Link to comment Share on other sites More sharing options...
///BHRpowered Posted May 8, 2008 Report Share Posted May 8, 2008 I have seen some of those, but the replica oem's?? the struts of course caught my eye, it looks like a bullshit search engine that just puts in anything, but how can there be struts that fit only 95-96? they should be interchangable atleast up to 00 if not 02. If there are infact true aftermarket ones now on the market...I feel I might just have to purchase a set Link to comment Share on other sites More sharing options...
ChiTown Posted May 8, 2008 Report Share Posted May 8, 2008 the 95-96 struts had a different size thread on top.... what about this....a eibach sway bar for the milly???never seen that: MILLY SWAY BAR??? Link to comment Share on other sites More sharing options...
///BHRpowered Posted May 8, 2008 Report Share Posted May 8, 2008 can the 95-06 struts be made to work with newer ones someone needs to order the eibach bars RIGHT AWAY, I personally do not have the funds at this time, but the rear does look like it would fit, but the front bar...hmm, questionable. Link to comment Share on other sites More sharing options...
ChiTown Posted May 9, 2008 Report Share Posted May 9, 2008 can the 95-06 struts be made to work with newer ones someone needs to order the eibach bars RIGHT AWAY, I personally do not have the funds at this time, but the rear does look like it would fit, but the front bar...hmm, questionable. I was told you can replace the upper strut mount and then it would be no problemo. Link to comment Share on other sites More sharing options...
mts Posted May 9, 2008 Author Report Share Posted May 9, 2008 can the 95-06 struts be made to work with newer ones someone needs to order the eibach bars RIGHT AWAY, I personally do not have the funds at this time, but the rear does look like it would fit, but the front bar...hmm, questionable. Bars are ordered... Link to comment Share on other sites More sharing options...
ing-schu@online.no Posted May 9, 2008 Report Share Posted May 9, 2008 Good find MTS can the 95-06 struts be made to work with newer ones someone needs to order the eibach bars RIGHT AWAY, I personally do not have the funds at this time, but the rear does look like it would fit, but the front bar...hmm, questionable. I was told you can replace the upper strut mount and then it would be no problemo. The older cars are supposed to have 12 mm threads, newer 10mm. But I got KYB's for 95-96 and they had 10mm threads, so I don't know what's correct... Anyway they fit my 00 without modifications to mention. In worst case the strutmount can be modified, no need to buy a new one. Fit a bush if downsizing, bore it out if upsizing. Piece of cake. Link to comment Share on other sites More sharing options...
mts Posted May 9, 2008 Author Report Share Posted May 9, 2008 Struts, lowering springs, and flowmaster exhaust with only one cat to follow.... Link to comment Share on other sites More sharing options...
Renboy Posted May 9, 2008 Report Share Posted May 9, 2008 If you're lowering your car and it has reasonably high mileage, then you should probably replace the strut mounts anyway. Good find MTS. Link to comment Share on other sites More sharing options...
mts Posted May 9, 2008 Author Report Share Posted May 9, 2008 I am half expecting to get a sway bar kit that won't fit Link to comment Share on other sites More sharing options...
ing-schu@online.no Posted May 9, 2008 Report Share Posted May 9, 2008 If you're lowering your car and it has reasonably high mileage, then you should probably replace the strut mounts anyway. Good find MTS. Why? They have no wearing parts at all unless rust is evident. The 26 mm front bar in this set has same dimension as the stock bar, why bother to replace that? The rear bar is way stiffer than the stock Xedos bar, 24mm instead of 16mm. It will decrease rear grip quite a lot, and probably turn the Milly into a tailhappy bitch Link to comment Share on other sites More sharing options...
mts Posted May 9, 2008 Author Report Share Posted May 9, 2008 Why bother? Because mine has major miles on it, and if I get the set... might as well use it. Link to comment Share on other sites More sharing options...
DoN_BLaZe34 Posted May 9, 2008 Report Share Posted May 9, 2008 are we expecting these eibach sway to really make a difference? Link to comment Share on other sites More sharing options...
Renboy Posted May 10, 2008 Report Share Posted May 10, 2008 The mounts are made of rubber and metal. The rubber ages and loses it's bond with the metal. No different than engine mounts, or harmonic balancers. Going from no swaybar, to a 24mm swaybar will truely turn it into 'a tailhappy bitch' as Xedos put it. Link to comment Share on other sites More sharing options...
mts Posted May 10, 2008 Author Report Share Posted May 10, 2008 Well I don't know why I bothered... some fuckin' drunk bastard side swiped the milly today. After he rear ended a classic TR6.... passenger side front to back was crunched by a fuckin' Avalanche... I have to take it for appraisal tomorrow... knowing insurance companies... they will try to write it off.... FUCK FUCK FUCK Link to comment Share on other sites More sharing options...
Renboy Posted May 10, 2008 Report Share Posted May 10, 2008 some fuckin' drunk bastard side swiped the milly today Kiss it goodbye. Given the damages will be closer to $6000 to fix, and given your mileage is so high, the car isn't worth it in the eyes of the insurance company. This is precisely the reason I think drunk drivers should be beaten to within an inch of their fucking lives (I mean that--good gory hollywood style beating), and then put into prison. After he rear ended a classic TR6 Nnnnnooooooo!!! Link to comment Share on other sites More sharing options...
MazdaMomma Posted May 10, 2008 Report Share Posted May 10, 2008 damn MTS.... soooooo, soooooooo sorry to hear that. Link to comment Share on other sites More sharing options...
Troutman Posted May 10, 2008 Report Share Posted May 10, 2008 God damn son of a bitch, this cannot be. Link to comment Share on other sites More sharing options...
///BHRpowered Posted May 11, 2008 Report Share Posted May 11, 2008 I'm mildly interested in making the struts fits, but I'm extremely interested in the sway kit, especially if the front fits. Link to comment Share on other sites More sharing options...
Renboy Posted May 11, 2008 Report Share Posted May 11, 2008 I'm mildly interested in making the struts fits, but I'm extremely interested in the sway kit, especially if the front fits. Have you not been paying attention? I can't believe I just asked that. Link to comment Share on other sites More sharing options...
mts Posted May 11, 2008 Author Report Share Posted May 11, 2008 some fuckin' drunk bastard side swiped the milly today Kiss it goodbye. Given the damages will be closer to $6000 to fix, and given your mileage is so high, the car isn't worth it in the eyes of the insurance company. This is precisely the reason I think drunk drivers should be beaten to within an inch of their fucking lives (I mean that--good gory hollywood style beating), and then put into prison. After he rear ended a classic TR6 Nnnnnooooooo!!! Sorry was wrong in my TR6.... a little flustered from the accident at that time... it was a 1979 MGB... but it looked unhurt compared to the damn Avalanche... Link to comment Share on other sites More sharing options...
///BHRpowered Posted May 11, 2008 Report Share Posted May 11, 2008 no ren I haven't been paying attention, I'v been driving for 18 hours, moving for the past month, and attempting to restore millenia greatness along with coming into my busy time of the year, so what part is so out landish. chitown said they could be made to fit, so I'm interested, I want the front sway bar from eibach, I just don't see it fitting, maybe the 2.5 though Link to comment Share on other sites More sharing options...
