latinopikachu Posted July 6, 2008 Report Share Posted July 6, 2008 now why the hell would you want to dronwn out hte sc Quote Link to comment Share on other sites More sharing options...
///BHRpowered Posted July 6, 2008 Report Share Posted July 6, 2008 I would have thought you went with a 70 series, alot of V8 Jeeps guys go with the 70 because its more streetable and less cabin noise, even the hemi guys think the 40 is alittle much Quote Link to comment Share on other sites More sharing options...
ing-schu@online.no Posted July 6, 2008 Report Share Posted July 6, 2008 So there are several types? This one is probably too loud for me even if I go for stock exhaust and headers /muffler. MTS, I think I'll pass it on to Frank or Ren, whoever was second on the list. I want a deeper note but not loud. Stock 2 previous gen BMW 5-series sound perfect Quote Link to comment Share on other sites More sharing options...
///BHRpowered Posted July 6, 2008 Report Share Posted July 6, 2008 several different ones 70 series is the most streetable, 40 is like hotrod, then theres the super44 which is fartcan loud Quote Link to comment Share on other sites More sharing options...
ing-schu@online.no Posted July 6, 2008 Report Share Posted July 6, 2008 Ok. Thanks for clearifying. Quote Link to comment Share on other sites More sharing options...
SteveSter Posted July 6, 2008 Report Share Posted July 6, 2008 I think the remus exhaust has the perfect sound, not to loud, but throaty. But didnt someone say they rust out quickly? Quote Link to comment Share on other sites More sharing options...
mts Posted July 6, 2008 Author Report Share Posted July 6, 2008 If you live somewhere where it snows... YES It is loud, but hey when you get such a sweet deal... Ren sounds like you have a muffler... Quote Link to comment Share on other sites More sharing options...
///BHRpowered Posted July 6, 2008 Report Share Posted July 6, 2008 rust, a remus? hell no my remus would stand up far better to anything other exhaust I'v seen, nwo the hangers the shop used, not from remus are a different story Quote Link to comment Share on other sites More sharing options...
///BHRpowered Posted July 6, 2008 Report Share Posted July 6, 2008 mts - it may be a jeep, but here is a comparison between a flowmaster 40 and 70 series exhausts, both with a high flow cat and magnaflow resonator, clear difference showing the 40 as much louder and deeper. Quote Link to comment Share on other sites More sharing options...
mts Posted July 6, 2008 Author Report Share Posted July 6, 2008 rust, a remus? hell no my remus would stand up far better to anything other exhaust I'v seen, nwo the hangers the shop used, not from remus are a different story You would actually have to drive yours to find out, and by that I mean in climatic conditons. Since yours is babied in the garage you have no fucking clue what woudl happen to all the exposed welds under there... Actually here are the specs on mine.... Material: 100% Stainless Steel - Mirror Finish Body Shape: 5in.x8in. Oval Inlet/Outlet Size: 2.25in./3in.x3.5in. Body Length: 14in. Overall Length: 24.5in. Core Size: Dual 2in. Position: Center Inlet/Dual Tip Outlet Features and Benefits: The Street Series is designed for the souped up street machine. It features a high flow tuning tube, balanced to the needs of the high revving import engine. The Street Series emits a smooth, deep tone while offering improved performance over OEM equipment. The Street Series is recommended for street cars with bolt-on performance modifications and custom body kits. Quote Link to comment Share on other sites More sharing options...
mts Posted July 6, 2008 Author Report Share Posted July 6, 2008 Seems they do not rate series 40 and 70 anymore... it is Street or Race Quote Link to comment Share on other sites More sharing options...
milenkogt Posted July 6, 2008 Report Share Posted July 6, 2008 The headers are available on eBay, but they really need to be modified to fit, the bolt pattern is wrong, the collector does not fit, the EGR tube needs to be drastically changed. The rear needs to have the flange cut off and moved to fit up inside. Then a high flow cat and a Magnaflow 18" resonator (not enough BTW second to be installed), then a the Series 40 Maganflow twin square tip muffler. when you say the bolt patten is wrong, you're talking about the flange connecting to the head? Do you have any more pictures from underneath the car maybe a full layout up front? After seeing the original manifolds, what kind of power do you think you picked up? Quote Link to comment Share on other sites More sharing options...
mts Posted July 6, 2008 Author Report Share Posted July 6, 2008 The middle lower bolt is about 10mm different location from 2.3 to 2.5, the flange has to be cut out and washers used to compensate the now slotted flange. This is the only bolt that doesn't match. If you order a top end gasket kit, you will notice that the lower bolt hole is oblong to account for the different heads... I am travelling now, cannot get more pics, but I will try when home again next weekend. As for power.... maybe a 10-15 HP increase by feel... but I am going to change plugs, change fluids and clean air filter when home and try to get on a local dyno for a pass... shall see. Quote Link to comment Share on other sites More sharing options...
latinopikachu Posted July 6, 2008 Report Share Posted July 6, 2008 the Fat Man has allowed me to hear Quote Link to comment Share on other sites More sharing options...
///BHRpowered Posted July 6, 2008 Report Share Posted July 6, 2008 remus is polished stainless steel in everything along with coated with basically rhino-liner at the joints, people that have had them all over and in conditions no millenia should ever face have had no problems. on the other hand, I can give you MANY examples of Jeep owners with rusted out FM systems Quote Link to comment Share on other sites More sharing options...
ChiTown Posted July 7, 2008 Report Share Posted July 7, 2008 The headers are available on eBay, but they really need to be modified to fit, the bolt pattern is wrong, the collector does not fit, the EGR tube needs to be drastically changed. The rear needs to have the flange cut off and moved to fit up inside. Then a high flow cat and a Magnaflow 18" resonator (not enough BTW second to be installed), then a the Series 40 Maganflow twin square tip muffler. So basically you have to massacre the headers then? I may just save time and strap on a remus, i dont want another rental......is the high-flow cat 2.5" in and 2.5" out ( if i stick with stock headers for now), i def need one of those..... Quote Link to comment Share on other sites More sharing options...
mts Posted July 7, 2008 Author Report Share Posted July 7, 2008 Headers are modified to the point of being only for the S, YES. The reason I did this.... Mazda stock manifolds with pre-cats, and a new main cat.... WAY TOO MUCH FUGGIN' MONEY. AND as a side note.... the O2 sensors are currently in stock positions, without ANY pre-cats, and NO P0421 and P0431 as expected... figure that one out... clean running engine? I had the one P0154 but the O2 sensor wire was loose. Quote Link to comment Share on other sites More sharing options...
Renboy Posted July 7, 2008 Report Share Posted July 7, 2008 That was indeed LOUD! Did they provide earplugs too? Good luck, enjoy your cruising Jokes aside, I wonder how much louder the Magnaflow resonator makes it compared to stock resonator? I listened to a soundfile with a MX6 with Magnaflow muffler, that wasn't this loud. I like the deep note, but it's too loud. Ren, is the stock MX6 exhaust note more or less similar to the Millenia? I know the 626 V6 is. Here is the sound I might want, cartainly not louder than this; MX6 with Magnaflow How can a man treat his engine like this, flipping the throttle like it's some excersize equipment? I can't open the file, and I'll just wait to see the car to see how loud it is. My car is pretty quiet on the outside, but because of my stiff engine mounts is pretty loud inside. My exhaust has the headers, a magnaflow resonator (biggest one the could shoe-horn under my car), and some cheap muffler. And since the mx6 sounds like a 626 here, then it should sould much like the 2.5 millenia. Quote Link to comment Share on other sites More sharing options...
mts Posted July 7, 2008 Author Report Share Posted July 7, 2008 How soon would you like to find out.... I am home next weekend on Saturday. Quote Link to comment Share on other sites More sharing options...
mohamedeladawy@hotmail.com Posted July 7, 2008 Report Share Posted July 7, 2008 dont pull a bhr. take a better quaility vid Quote Link to comment Share on other sites More sharing options...
mts Posted July 7, 2008 Author Report Share Posted July 7, 2008 When I have time... too busy enjoying driving it this weekend.... Quote Link to comment Share on other sites More sharing options...
MazdaMomma Posted July 9, 2008 Report Share Posted July 9, 2008 I would love to hear... Quote Link to comment Share on other sites More sharing options...
mts Posted July 14, 2008 Author Report Share Posted July 14, 2008 Going tomorrow to see about a second resonator... Quote Link to comment Share on other sites More sharing options...
///BHRpowered Posted July 14, 2008 Report Share Posted July 14, 2008 MTS - you mentioned a loose wire, once fixed are you encounted any CEL's or problems with the new exhaust, I'm very curious what emissions will be without the pre-cats Quote Link to comment Share on other sites More sharing options...
latinopikachu Posted July 14, 2008 Report Share Posted July 14, 2008 WAY TOO MUCH FUGGIN' MONEY. haha. why is it i can hear the Fat Man saying that Quote Link to comment Share on other sites More sharing options...
