Matt64341 Posted March 18, 2009 Report Share Posted March 18, 2009 really, because once again you are uninformed and confusing people. 1. 95's, about 90% had OBD1 - just ask marcus, or camel or anyone else 2. The codes listed are OBD1 there is a 0100, but 1000, etc are not listed on ANY obd 2 source No... all Millenia's in the US are OBD-II compatible 1995 is no different. They were all shipped out with OBD-II compatibility stickers and the systems were in place. Later Mazda voluntarily chose to re-sticker the 95 models to state OBD-I compatible, which could be due to the hard to find location of the OBD port or maybe just minor problems in the system itself. But regardless of their reasoning, all the codes are OBD-II codes and can be read by any OBD-II scanner. The reason you couldn't find all of the codes is because some are manufacturer specific, if you look in the FSM, they are all there. P0100 - MAF circuit malfunction P1000 - All tests not complete (ignore this code, it does not indicate a problem and goes away on its own) P1402 - EGR Valve Position Sensor P1601 - ECM/TCM Communication Error I would first fix all the vacuum lines, clean the MAF, and erase the codes. The P1402 could be vacuum related and P1601 could just be a side effect of the vacuum problems or a one time code that won't come back. Then see what comes back or if you are still having problems. Quote Link to comment Share on other sites More sharing options...
enginph Posted March 18, 2009 Report Share Posted March 18, 2009 I got a similar communication error just once. And I think it was because of my weak battery. One day I fire it up and CEL stayed on. When I read it was the communication error. Erased it and never popped up again for the last two years. Quote Link to comment Share on other sites More sharing options...
ChiTown Posted March 18, 2009 Report Share Posted March 18, 2009 my old milly, production year 1994 was not OBD2. Quote Link to comment Share on other sites More sharing options...
enginph Posted March 18, 2009 Report Share Posted March 18, 2009 my old milly, production year 1994 was not OBD2. I thought so but wasnt sure. Now you said that... BHR is right once again Quote Link to comment Share on other sites More sharing options...
Matt64341 Posted March 18, 2009 Report Share Posted March 18, 2009 Mine is dated 06/94, and MillyOwner's is a couple months older than that (I want to say it is 04/94), both OBD-II. Are you really sure that it was not compatible? The port is in an obscure place, and the stickers state that it is OBD-I. In almost every old post I have read through, people are convinced that there is no port, when they look in the correct place it is there. I could not find a single person who posted that they did not have a port with any evidence that it was true, and many that later found it. I am also not sure if MillyOwner has a 95 S or L, I suppose it could be something they tried on the S in early production and not the L... Quote Link to comment Share on other sites More sharing options...
enginph Posted March 18, 2009 Report Share Posted March 18, 2009 Mine is dated 06/94, and MillyOwner's is a couple months older than that (I want to say it is 04/94), both OBD-II. Are you really sure that it was not compatible? The port is in an obscure place, and the stickers state that it is OBD-I. In almost every old post I have read through, people are convinced that there is no port, when they look in the correct place it is there. I could not find a single person who posted that they did not have a port with any evidence that it was true, and many that later found it. I am also not sure if MillyOwner has a 95 S or L, I suppose it could be something they tried on the S in early production and not the L... He had a 2.5 before. Quote Link to comment Share on other sites More sharing options...
///BHRpowered Posted March 18, 2009 Report Share Posted March 18, 2009 I'm not sure if there is a baised between the S and the 2.5, but 96 was the year OBD was required, and there have been more then a handful of accounts stating OBD1 on 95, infact I have yet to find someone with a confirmed 1995 OBD2 Quote Link to comment Share on other sites More sharing options...
MURRAYBRYSON786 Posted March 19, 2009 Author Report Share Posted March 19, 2009 well i pulled the codes on an obd2 reader and the codes above are the codes it puled i just finished replacing all of my vacuum lines and it runs alot better but it still dies when i come to a stop is that because of the Egr? also when i pulled the front intercooler (or whatever it is call on a S/C) it had a lot of oil in it and a bunch of my vacuum lines have oil in them and about the PCV valve i pulled the hose off of it and placed a filter over both ends and the car ran alot better i think most of theoil in my intake is from that stupid valve Quote Link to comment Share on other sites More sharing options...
MURRAYBRYSON786 Posted March 19, 2009 Author Report Share Posted March 19, 2009 i am going to get the codes erased tonight and was looking at this product called restore it it restores compression in you cylinders dose it really work? i know that i am getting a miss fire at low RPMs and that is why my engine dies when i come to a complete stop. do you think i should give this restore a try? Quote Link to comment Share on other sites More sharing options...
enginph Posted March 19, 2009 Report Share Posted March 19, 2009 well i pulled the codes on an obd2 reader and the codes above are the codes it puled i just finished replacing all of my vacuum lines and it runs alot better but it still dies when i come to a stop is that because of the Egr? also when i pulled the front intercooler (or whatever it is call on a S/C) it had a lot of oil in it and a bunch of my vacuum lines have oil in them and about the PCV valve i pulled the hose off of it and placed a filter over both ends and the car ran alot better i think most of theoil in my intake is from that stupid valve What did you do exactly? You can change the valve.So much oil shouldnt come from there. i am going to get the codes erased tonight and was looking at this product called restore it it restores compression in you cylinders dose it really work? i know that i am getting a miss fire at low RPMs and that is why my engine dies when i come to a complete stop. do you think i should give this restore a try? I wouldnt mess it up more. You have some problems with intake air being not enough i think.. ECM should open IAC valve when the car comes to a complete stop. If there is communication issues between ECM and TCM, ECM may not be able to know tranny is engaging to gear while the car is stopping. http://members.cox.net/sciberpunkt/tech/obd/p0100/ It may also be the EGR though. Quote Link to comment Share on other sites More sharing options...
Matt64341 Posted March 19, 2009 Report Share Posted March 19, 2009 I'm not sure if there is a baised between the S and the 2.5, but 96 was the year OBD was required, and there have been more then a handful of accounts stating OBD1 on 95, infact I have yet to find someone with a confirmed 1995 OBD2 ... I have an OBD-II 95, I can take a picture of the reader working if you don't believe it. Some of the accounts I found said that the port is behind the drivers side kick panel, you would need to be searching to find it. The reason for the recall of the OBD-II status on the 95 could very well be just because the placement of the port violates the standard, but the rest of the system is in place. Quote Link to comment Share on other sites More sharing options...
Frankzao Posted March 19, 2009 Report Share Posted March 19, 2009 miss fires usually indicate a coil problem as well. Quote Link to comment Share on other sites More sharing options...
MURRAYBRYSON786 Posted March 19, 2009 Author Report Share Posted March 19, 2009 so i erased the codes and unfortunatly 2 of them would not erase the Po1oo & P1ooo is this a sign of a bad computer? Quote Link to comment Share on other sites More sharing options...
SteveSter Posted March 19, 2009 Report Share Posted March 19, 2009 No those test are instant so they can come back very quickly. Im going to go with something wrong with the egr system. If your EGR opens while at idle the car will stall and shut off. So I would check its not sticking. Take it off and clean it. Check your MAF connections and clean it out with MAF sensor cleaner. Quote Link to comment Share on other sites More sharing options...
///BHRpowered Posted March 19, 2009 Report Share Posted March 19, 2009 there shouldn't be alot of oil, but replacing the PCV valve might make a difference, might not. but they do clog restore is just a garbage product and doesn't work, it won't do harm - but it won't restore anything In terms of cleaning I use "GUNK" oil cleaner for the oil, and a decent number of people have used seafoam. I personally have had zero luck with seafoam since my engines are always clean, but in your case I would recommend it. You can also remove the EGR and clean it up with brake cleaner or something. I have seen them be nearly clogged before. Quote Link to comment Share on other sites More sharing options...
mts Posted March 19, 2009 Report Share Posted March 19, 2009 Easy check for PCV, remove it and shake it... if it clicks up and down... chances are it is OK Quote Link to comment Share on other sites More sharing options...
///BHRpowered Posted March 19, 2009 Report Share Posted March 19, 2009 clicks I'm tempted to try that, but the damn thing is wicked piss hard to get off, and the angle doesn't help. Should just remove tube and twist down or up Quote Link to comment Share on other sites More sharing options...
mts Posted March 19, 2009 Report Share Posted March 19, 2009 Twist and pull, should pop right out of grommet.... really easy. Yours is likely gummed up and stuck in there, if hard. Quote Link to comment Share on other sites More sharing options...
enginph Posted March 19, 2009 Report Share Posted March 19, 2009 Twist and pull, should pop right out of grommet.... really easy. Yours is likely gummed up and stuck in there, if hard. Is mine so loose? I can easily take it out.. As easy as tranny dip stick. Quote Link to comment Share on other sites More sharing options...
///BHRpowered Posted March 19, 2009 Report Share Posted March 19, 2009 no, its just the angle. On my jeep I could never get it to turn, but you have to push down, turn, pull up, then twist. God damn pcv Quote Link to comment Share on other sites More sharing options...
mts Posted March 19, 2009 Report Share Posted March 19, 2009 You are a pussy.... grow a set and go pull out the PCV Quote Link to comment Share on other sites More sharing options...
Matt64341 Posted March 19, 2009 Report Share Posted March 19, 2009 Just don't do it in the cold or you will snap the plastic hose. I did that to mine, and the one at the junkyard too... It is repaired right now but I still want to replace it at some point. Quote Link to comment Share on other sites More sharing options...
mts Posted March 19, 2009 Report Share Posted March 19, 2009 They are only about $20 at most parts places. I think?? Quote Link to comment Share on other sites More sharing options...
Matt64341 Posted March 19, 2009 Report Share Posted March 19, 2009 It looks like a custom molded hose, it probably could be replaced with rubber hose, but rubber does not mix well with oil, so I havn't tried that yet. I was also considering trying one of those inline PVC oil separators so that would require a different hose too. I would be interested to see how much oil passes through the PVC and back into the supercharger. Quote Link to comment Share on other sites More sharing options...
enginph Posted March 19, 2009 Report Share Posted March 19, 2009 It looks like a custom molded hose, it probably could be replaced with rubber hose, but rubber does not mix well with oil, so I havn't tried that yet. I was also considering trying one of those inline PVC oil separators so that would require a different hose too. I would be interested to see how much oil passes through the PVC and back into the supercharger. It smokes a lot. I realized it when doing seafoam. I cant imagine how much under load. The smoke may partially because of Mobil1. Quote Link to comment Share on other sites More sharing options...
