DoN_BLaZe34 Posted November 8, 2006 Author Report Share Posted November 8, 2006 i didn't say i don't believe u..i said i don't believe what people told u because obviously it can be done...people tried to tell me that my eibach springs weren't meant for my car and that was wrong too when it comes to shit with the millenia, people are quick to tell you it can't be done, when in fact it can...that was simply my point..u said u didn't take offense, but u took the time to thank me for not believing you, which i just took the time to try to clarify for u..i don't get it Quote Link to comment Share on other sites More sharing options...
mohamedeladawy@hotmail.com Posted November 8, 2006 Report Share Posted November 8, 2006 is it possible to get a block heater if u live in an apartment? how does it work? are there portable ones? Quote Link to comment Share on other sites More sharing options...
///BHRpowered Posted November 8, 2006 Report Share Posted November 8, 2006 I have no idea why someone would say that about the eibachs, when there designed for eibach by the car. the remote start issue has only come up due to all the problems people have had over the years Quote Link to comment Share on other sites More sharing options...
mts Posted November 8, 2006 Report Share Posted November 8, 2006 is it possible to get a block heater if u live in an apartment? how does it work? are there portable ones? It is only a little 1500W heater element that goes into the water jacket of the engine and keeps the coolant warm. Plugs into any 110V outlet Quote Link to comment Share on other sites More sharing options...
DoN_BLaZe34 Posted November 9, 2006 Author Report Share Posted November 9, 2006 I have no idea why someone would say that about the eibachs, when there designed for eibach by the car. the remote start issue has only come up due to all the problems people have had over the years yes, but eibach lists the 95-01's...the 02 isn't included on there...hence the doubt Quote Link to comment Share on other sites More sharing options...
MazdaMomma Posted November 9, 2006 Report Share Posted November 9, 2006 i didn't say i don't believe u..i said i don't believe what people told u because obviously it can be done...people tried to tell me that my eibach springs weren't meant for my car and that was wrong too when it comes to shit with the millenia, people are quick to tell you it can't be done, when in fact it can...that was simply my point..u said u didn't take offense, but u took the time to thank me for not believing you, which i just took the time to try to clarify for u..i don't get it I was giving you a hard time Don. The places I took the milli to had tried it and just could not get the damn things to work properly. Quote Link to comment Share on other sites More sharing options...
ing-schu@online.no Posted November 9, 2006 Report Share Posted November 9, 2006 xedos - it only warms up the inside of the car if you leave it running for along time, burning the gas of course. the stuff you speak of is what I use to have for the millenia, well still do but do not need. a battery blanket heater, engine block heater. this makes it much easier to safe the car and does not let the engine do damage to itself in extreme cold. remote start just starts the car, if turning the key won't start it due to cold, neither will the remote start I don't quite understand, you mean the Webasto only warms up the inside of the car? Sure, such Webastos also exist, but I'm thinking of those heating the coolant, and then, as an option, the cars own fan can warm up the cabin using the heater core. They then need a voltage sensor, to avoid the battery being drained too much to start the car. It is not a good idea to do only short trip driving with this feature due to recharge needing some driving. My block heater is only 500 watts actually, enough to warm up the engine in 2 hours. It is supposed to raise coolant temperature about 40 degrees C above outside temperature. Typically the engine becomes hand warm after two hours though, even when freezing cold. The engine starts almost without raised idle at all. Anubis, you need a power outlet, obviously. Or a remote start generator Quote Link to comment Share on other sites More sharing options...
///BHRpowered Posted November 9, 2006 Report Share Posted November 9, 2006 xedos, let me put it another way, the remote start does nothing at all but start the car. which means by remote, you can start the engine, so if you leave the heat turned on when you left it, the heat will come on, and heat up the inside of hte car. the oil, battery, coolant, gear lube, whatever, will not warm up at all except for the heat from an idling engine Quote Link to comment Share on other sites More sharing options...
ing-schu@online.no Posted November 9, 2006 Report Share Posted November 9, 2006 I've never heard of engine and tranny oils not warming up with the engine idling but fair enough, I get your point. Quote Link to comment Share on other sites More sharing options...
///BHRpowered Posted November 9, 2006 Report Share Posted November 9, 2006 they will warm up, but the point is, no faster then if you turned the key. the kits mts and me are talking about do not require the engine to be running, yo simply plug them into a walla outlet and they keep the fluids warm all night long Quote Link to comment Share on other sites More sharing options...
Dallasaurora Posted November 10, 2006 Report Share Posted November 10, 2006 Not that I'm an expert but DoN's question hasn't been answered yet, has it ? Quote Link to comment Share on other sites More sharing options...
DoN_BLaZe34 Posted November 10, 2006 Author Report Share Posted November 10, 2006 expert or no expert, you were smart enough to know that my question had in fact NOT been answered dal... anyway i think it turned out that i had to get the system reprogrammed to crank longer...i think this may have fixed the problem although i won't know until tomorrow.. Quote Link to comment Share on other sites More sharing options...
Dallasaurora Posted November 10, 2006 Report Share Posted November 10, 2006 Was just funny how it ended up being about heating engines rather than the remote start issue Anyway, glad it's being sorted, you gone to a pro ? Quote Link to comment Share on other sites More sharing options...
ing-schu@online.no Posted November 10, 2006 Report Share Posted November 10, 2006 My question and suggestion actually was meant as a possible optional solution to the remote start, which in fact would be considered illegal here. Not to install, but to use. Quote Link to comment Share on other sites More sharing options...
mts Posted November 10, 2006 Report Share Posted November 10, 2006 Quote Link to comment Share on other sites More sharing options...
DoN_BLaZe34 Posted November 10, 2006 Author Report Share Posted November 10, 2006 Was just funny how it ended up being about heating engines rather than the remote start issue Anyway, glad it's being sorted, you gone to a pro ? yeah i decided to go back to the place i had it installed and they helped.. My question and suggestion actually was meant as a possible optional solution to the remote start, which in fact would be considered illegal here. Not to install, but to use. you were in fact tryin to help xedos, therefore i thank you Quote Link to comment Share on other sites More sharing options...
ing-schu@online.no Posted November 11, 2006 Report Share Posted November 11, 2006 You are welcome I'm glad you got it sorted. Quote Link to comment Share on other sites More sharing options...
Hitman Posted November 12, 2006 Report Share Posted November 12, 2006 And what is the current result? Quote Link to comment Share on other sites More sharing options...
DoN_BLaZe34 Posted November 14, 2006 Author Report Share Posted November 14, 2006 it seems the cranking time on the system needed to be adjusted..all is well now..minus my tires Quote Link to comment Share on other sites More sharing options...
latinopikachu Posted November 14, 2006 Report Share Posted November 14, 2006 *Whoring is not allowed in this section* Post deleted Quote Link to comment Share on other sites More sharing options...
MazdaMomma Posted November 15, 2006 Report Share Posted November 15, 2006 I missed it. What happened to your tires Don? Quote Link to comment Share on other sites More sharing options...
///BHRpowered Posted November 15, 2006 Report Share Posted November 15, 2006 he got 2 flats Quote Link to comment Share on other sites More sharing options...
MazdaMomma Posted November 16, 2006 Report Share Posted November 16, 2006 thanks BHR. Don, contact jdubs reguarding your remote start problem. He may be able to help. Quote Link to comment Share on other sites More sharing options...
DoN_BLaZe34 Posted November 16, 2006 Author Report Share Posted November 16, 2006 already taken cared of mc Quote Link to comment Share on other sites More sharing options...
MazdaMomma Posted November 18, 2006 Report Share Posted November 18, 2006 Oh well... Glad to hear that tho Don. Quote Link to comment Share on other sites More sharing options...
