///BHRpowered Posted January 8, 2007 Report Share Posted January 8, 2007 Ok, I have had a hayden transmission cooler sitting around the garage for almost a year now, finally have some time. So, how exactly do you install them? for example. do I need to cut any lines with transmission or or coolant in them? if so, where are these lines located and what is involved, I mean do I need to add more fluid in to top it off, or will it all drain out and I have to completely refill whatever. Where and how can I mount it? I suppose in the front grill would be best, but could I place it under the engine bay or inside and just have an electric fan on it? I'm 95% sure I have to cut a transmission line, how do I do this in a safe manner, and again, will everything drain out and me have to refill? Also, is there any affect for when I get the transmission flushed? as I plan on having done in march. Thanks. Quote Link to comment Share on other sites More sharing options...
Dallasaurora Posted January 8, 2007 Report Share Posted January 8, 2007 Xedosman is your expert on this. I wanted to install one as well, so a nice write up/pics would come in useful. Quote Link to comment Share on other sites More sharing options...
ing-schu@online.no Posted January 8, 2007 Report Share Posted January 8, 2007 Xedosman is your expert on this. I wanted to install one as well, so a nice write up/pics would come in useful. Dallas, I appreciate your confidence in my knowledge on this subject, I will however reject the therm expert being used on my oilcooler skills. I'm the Scorpio Expert, remember? However I do know how my stock cooler is hooked up, sent you some pics as you surely will remember. It is mounted in front of the radiators, down under the bumper, in the airflow entering the bottom bumper opening. It is attached in series with the stock left side trannycooler, which uses a part of the coolant radiator. A quick look under the hood reveals the hoses attached to this cooler, which I suppose all Millenias have. An extra cooler will therefore have to be attached into this circuit, supposedly after the present cooler. A quick start after dismantling hoses will reveal the direction of coolant flow, a messy procedure... Be sure to have a bucket and a trustworthy ignition operator. Lats recent technical info implies the whereabouts of the stock cooler, with a drawing and all. I should say this is a good plaze to start After fitment I'd suggest a tranny flush through the cooler lines, this has been described in a tranny thread I had here. Or was it in another world? Don't remember... I do these flushes every 60000 km, the last time using Dexron III synthetic ATF, highly recommended. My tranny works perfect, inspite the towing, hold button use and all it's strained with. My latest towing adventure unfortunately implied a boggitrailer with partly frozen brakes, which I tackled with throttle, even more throttle and, correct, HOLD button. 7 km's was enough to make sure the trannycooler works, to put it that way. Not much more than hand warm though. Quote Link to comment Share on other sites More sharing options...
///BHRpowered Posted January 9, 2007 Author Report Share Posted January 9, 2007 Xedos, I'm not aware of any millenia having a stock transmission cooler, atleast not in the states. I try to get the fluid changed every 25-30k at the most though, My plan was to get this installed just before my service trip. Will the front bumper cover need to be removed? Quote Link to comment Share on other sites More sharing options...
ing-schu@online.no Posted January 9, 2007 Report Share Posted January 9, 2007 Are you sure? My car certainly has, added up with one in front of the radiators. Now I'm aware the front one is additional, but I really do believe all models have the left handside radiator ATF cooler, look below the coolant reservoir, and see if there are two thin hoses (way thinner than the engine coolant hoses that is) attached with banjo fittings in the upper and lower part on far left of the radiator. Also look into this link, Lats brilliant work should be studied by anyone wanting to learn about their Milly/ Xedos/ Eunos: http://i28.photobucket.com/albums/c234/Fuj...lsys/img086.jpg I guess your front bumper will have to come off to get access to the mounting area of an additional cooler, it is crazy tight in there. You will have to manufacture a bracket to secure the cooler, either transverse or from top to bottom in front of the coolers. Low left but not far left side would be my guess of the best plaze, in the area behind the lower bumper opening. I should not think a fan should be necessary, while driving there is plenty airflow. Quote Link to comment Share on other sites More sharing options...
mts Posted January 9, 2007 Report Share Posted January 9, 2007 Well done. Quote Link to comment Share on other sites More sharing options...
DoN_BLaZe34 Posted January 9, 2007 Report Share Posted January 9, 2007 as far as i know as well, the milly does NOT have a stock tranny cooler...and when i installed mine, i did not take off the front bumper...but then again i have an L Quote Link to comment Share on other sites More sharing options...
excluesiveonez Posted January 9, 2007 Report Share Posted January 9, 2007 in europe they did.. they also had a tow package as well Quote Link to comment Share on other sites More sharing options...
mts Posted January 9, 2007 Report Share Posted January 9, 2007 I will have to check when I get home Quote Link to comment Share on other sites More sharing options...
///BHRpowered Posted January 9, 2007 Author Report Share Posted January 9, 2007 there damn well better not be a tow package. but yes, no u.s one does. I don't know of anyone that added on to an S, only the L, so I'm not sure about clearance. I would just pay someone to do it, but if you have to fab brackets I don't want to pay for that Quote Link to comment Share on other sites More sharing options...
mts Posted January 9, 2007 Report Share Posted January 9, 2007 There is a tow package in Europe. Quote Link to comment Share on other sites More sharing options...
ing-schu@online.no Posted January 9, 2007 Report Share Posted January 9, 2007 Some pics from my 1500 kg worth of towing Xedos: [attachmentid=417] [attachmentid=418] [attachmentid=419] Quote Link to comment Share on other sites More sharing options...
mts Posted January 9, 2007 Report Share Posted January 9, 2007 Nope do not have that... Quote Link to comment Share on other sites More sharing options...
ing-schu@online.no Posted January 9, 2007 Report Share Posted January 9, 2007 Really, not the banjo under the coolant reservoir either? Quote Link to comment Share on other sites More sharing options...
mts Posted January 9, 2007 Report Share Posted January 9, 2007 Won't know that until I can look at it. I have a Dodge Charger for the next 3 days Quote Link to comment Share on other sites More sharing options...
ing-schu@online.no Posted January 9, 2007 Report Share Posted January 9, 2007 Not the Bullit kind of Charger? Quote Link to comment Share on other sites More sharing options...
mts Posted January 9, 2007 Report Share Posted January 9, 2007 One of these... Quote Link to comment Share on other sites More sharing options...
ing-schu@online.no Posted January 9, 2007 Report Share Posted January 9, 2007 Ok. I think I like the Crysler 300 C slightly better for looks, but I guess that is an ok car to drive. Merc W126 suspension parts. In the Crysler anyway. Quote Link to comment Share on other sites More sharing options...
DoN_BLaZe34 Posted January 9, 2007 Report Share Posted January 9, 2007 those are nice looking cars...well at least i think Quote Link to comment Share on other sites More sharing options...
///BHRpowered Posted January 9, 2007 Author Report Share Posted January 9, 2007 indeed xedos, I have nothing of the sort on mine either Quote Link to comment Share on other sites More sharing options...
mts Posted January 10, 2007 Report Share Posted January 10, 2007 They are tough looking cars that are actually nice to drive for domestics... Quote Link to comment Share on other sites More sharing options...
///BHRpowered Posted January 10, 2007 Author Report Share Posted January 10, 2007 not really a fan. So does anyone know someone who has put these on an S? its hte hayden btw..I wonder about malice Quote Link to comment Share on other sites More sharing options...
mts Posted January 10, 2007 Report Share Posted January 10, 2007 Quote Link to comment Share on other sites More sharing options...
mohamedeladawy@hotmail.com Posted January 10, 2007 Report Share Posted January 10, 2007 ya we dont have it...this is a pic of where it would be...nothing there. Quote Link to comment Share on other sites More sharing options...
tristan_cauvin Posted January 10, 2007 Report Share Posted January 10, 2007 man you need to spray some black paint on yo' crap or something lol Quote Link to comment Share on other sites More sharing options...
