Frankzao Posted February 27, 2007 Report Share Posted February 27, 2007 Some of the links in your thread (see below are not working). How to Decipher OBD-II Trouble Codes (such as P0030, etc.) doesn't and How to Change Spark Plugs on the S model doesn't either. We need one for 'How to check the CEL codes and what do they mean' . The CEL's in both my millys are on......... TECHNICAL SERVICE BULLETINS (TSB's): TSB's for all Millenia years and engines HOW TO GUIDES: How to Replace the Supercharger How to Remove and Install the Oil Pan How to Replace the 120A Main Fuse How to Change the Fuel Filter How to Change Fuel Injectors How to Replace OEM O2 sensors with Generic O2 sensors How to Change the Coolant How to Change the Serpentine Belts How to Program the Remote How to Change Spark Plugs on the S model How to Modify the Fog Lights to work independently How to Change the Knock Sensor on the 2.5 How to Change the Valve Cover Gaskets How to Aim the Foglights How to Install Dashboard Gauges How to Change Blubs in Headlights and Parking Lights How to Remove the Stereo Head Unit How to Replace the Tie Rod End How to Replace the Lateral Links How to Install an Aftermarket Transmission Cooler How to Install Timing Belt How to Decipher OBD-II Trouble Codes (such as P0030, etc.) How to fix EGR troubles COMMON PROBLEMS AND SOLUTIONS: Problem - Heated Seat Elements don't work Problem - A/C Blower Fan making a chattering noise Problem - Power Tilt Wheel doesn't work Problem - Trunk Release Button doesn't work Problem - Car Overheats Problem - Musty Smell from A/C COMMON QUESTIONS: Question - Panasonic OEM CD Changer Compatability for various model years Question - Keyless Entry Remote Control Compatability for various model year Question - 1995 OBDII Compatability Question - Mazda's 100 point checklist Question - What are the fluid capacities REPAIR GUIDES: Free Online Repair Guide Quote Link to comment Share on other sites More sharing options...
mts Posted February 27, 2007 Report Share Posted February 27, 2007 Well the Decypher page seems to have been deleted on another server... beyond our control... I will try to find another... The Changing of the plugs? Refers to this site.... Syn was this deleted somewhere? Quote Link to comment Share on other sites More sharing options...
Frankzao Posted February 27, 2007 Author Report Share Posted February 27, 2007 One should copy the info to this site and just post the link for reference. That way we won't lose such information in the future. As you know the web is always changing. Quote Link to comment Share on other sites More sharing options...
mts Posted February 27, 2007 Report Share Posted February 27, 2007 Have at it.... Quote Link to comment Share on other sites More sharing options...
///BHRpowered Posted February 27, 2007 Report Share Posted February 27, 2007 I know it wasn't deleted, however if it was moved into the tech section and the title changed then the link may have to be redone, easy enough Quote Link to comment Share on other sites More sharing options...
latinopikachu Posted February 27, 2007 Report Share Posted February 27, 2007 this is interesting indede Quote Link to comment Share on other sites More sharing options...
mts Posted February 27, 2007 Report Share Posted February 27, 2007 Who did that? Quote Link to comment Share on other sites More sharing options...
latinopikachu Posted February 27, 2007 Report Share Posted February 27, 2007 certainly not me, ive been to busy with my amati books Quote Link to comment Share on other sites More sharing options...
mts Posted February 27, 2007 Report Share Posted February 27, 2007 Quote Link to comment Share on other sites More sharing options...
Frankzao Posted February 27, 2007 Author Report Share Posted February 27, 2007 wasn't I Quote Link to comment Share on other sites More sharing options...
mts Posted February 27, 2007 Report Share Posted February 27, 2007 We know that.... Quote Link to comment Share on other sites More sharing options...
latinopikachu Posted March 1, 2007 Report Share Posted March 1, 2007 Quote Link to comment Share on other sites More sharing options...
Hitman Posted March 1, 2007 Report Share Posted March 1, 2007 When lat moved multiply threads into the tech section and renamed them afterwards, in order to properly express there content the merge link was broken. Tonight I shall go back though and reconnect. Quote Link to comment Share on other sites More sharing options...
latinopikachu Posted March 2, 2007 Report Share Posted March 2, 2007 i didnt move those threads. mts did. I've only deleted one in the amati section. Quote Link to comment Share on other sites More sharing options...
mts Posted March 2, 2007 Report Share Posted March 2, 2007 Move? I did not.... Quote Link to comment Share on other sites More sharing options...
